Uploads by Philbey
Jump to navigation
Jump to search
This special page shows all uploaded files.
| Date | Name | Thumbnail | Size | Description | Versions |
| 00:24, 19 January 2010 | Dashpinske11to17.jpg (file) | ![]() |
56 KB | 1 | |
| 00:20, 19 January 2010 | Dashpins.jpg (file) | ![]() |
96 KB | 1 | |
| 14:12, 21 May 2008 | New top in place.JPG (file) | 116 KB | KE10 Strut with a KE20 upper spring perch fitted using a spacer. | 1 | |
| 14:06, 21 May 2008 | Spacer fitted.JPG (file) | 140 KB | Spacer sitting inside strut top | 1 | |
| 13:56, 21 May 2008 | Top comparison.JPG (file) | 114 KB | KE20 upper spring perch on the left, KE10 on the right | 1 | |
| 13:51, 21 May 2008 | Removed.jpg (file) | ![]() |
138 KB | 1 | |
| 13:43, 21 May 2008 | Removed.JPG (file) | 138 KB | All apart | 1 | |
| 13:37, 21 May 2008 | Rubber and multigrips.JPG (file) | 126 KB | Rubber wrapped around shock rod to grip while you rattlegun it off | 1 | |
| 13:25, 21 May 2008 | Spring off 2.JPG (file) | 129 KB | Coil wound down strut body | 1 | |
| 13:23, 21 May 2008 | Spring off 1.JPG (file) | 128 KB | Pic with the spring "popped" off the lower spring perch | 1 | |
| 13:12, 21 May 2008 | Ke1x assy no spring numbered.JPG (file) | 105 KB | KE10 front strut with the spring removed. Numbered for explanation. | 1 |
