Series:A/Model/AE80/82/AE80/82 Body Panels
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
This is a guide as to what panels fit where.
Bonnet: All bonnets are the same from AE80/82 sedan, seca and hatch.
Headlights: Even though the front end is different from the S1 to the S2/3, they still use the same headlights.
Grille: Alot of people prefer the S2 "twincam" style grille, these can be installed on an S1 but you need to file down the sides of the grille as the S2/3 lights are further apart.
Front Bumper Bars: All front bumper bars mount the same.
Rear Bumper Bars: Hatch rear bumpers only fit a hatch, sedan and seca are interchangeable although you need to trim a bit off the inside of the bar when putting it on a sedan due to the squarer rear and a seca with a sedan rear bar will have a large gap under the indicators.
Front Doors: Sedan and hatch front doors are interchangeable, seca has a different door due to the windscreen being laid back more.
Rear Doors: All rear doors are different. The hatch has a flat top 4 sided quarter window, sedan has a pointy top 3 sided (slight curve in rear) quarter window and seca has pointy top 3 sided triangle quarter window.
Guards: The guards are the same between sedan, seca and hatch but the difference comes from it being either a S1 or S2/3.
Mirrors: Sedan and hatch mirrors are the same whereas the seca has it's own mirrors.
Article by Trev.
