Tech:Engine/K Series/Boosted K motors
Revision as of 02:25, 6 May 2010 by Taz rx (talk | contribs)
Cheers, Si (Taz_RX)
Firstly, obviously there is two way to build a "Boosted K motor" by using a turbo or a supercharger. For deffinitions or how each work (if you don't know and are intersted) please do a wiki/google search.
Superchargers:
What to use: The most common superchargers used on K motor are Toyota SC12 (4AGZE) and SC14 (1GGZE) units. These are readily available from import motors, wreckers etc and are quite reasonable priced. Others have used other superchargers like the AMR300 or AMR500 however both of these units are quite smaller compared to the SC chargers. This isn't to say they won't work though, its just by the time you get up in the revs a bit the small capacity of the charger may restrict top end flow. At the other end of the scale you could use a bigger charger like and Eaton M series (M90 from S pac supercharged commodore for example) which geared correctly could give great top end flow, however some boost lag would be expected in the bottom end of the rev range. Choosing the size of the charger, and the gearing used is just like picking a cam shaft or turbo A/R ratio. It really depends on what you want to use the car for and where you want your power range. The easiest way to hang a supercharger off a K motor is to source yourself an air-conditioning bracket off any K motor. With a few minor mods to the bracket and/or the charger itself you can
