Tech:Engine/K Series/Valve Clearances
Revision as of 05:22, 17 September 2009 by Taz rx (talk | contribs)
The valve clearances for 3/4k for adjustable lifters are:
.008" & .012" when hot and .005" & .009" when cold (thou - thousanths of an inch)
These are for motors with STOCK cams. When upgrading to a bigger aftermarket camshaft consult you cam grinder for new valve clearnaces. Some cams shops even list them in their on-line catalogues.
5k's, having hydraulic lifters do not have an adjustable valve clearance. If converting to solids use the above 3/4k specs (stock cams) or consult your cam grinder (for aftermarket).
When setting the valve clearances always make sure the cylinder you are working on is on its compression stroke. This is easy to do: With the tappet cover off turn the motor over (spanner on crank pulley) until you see the appropiate inlet valve open, keep turning till it closes and then give it another 1/4 turn or so. DON'T go so far that you start to open up the exhaust valve, you basically want it half way between the inlet closing, and exhaust opening. At this point both rockers should be "loose". Adjust both tappet and move onto the next cylinder.
Aftre replacing a head gasket, its not a bad idea to check and re-adjust the tappets if required after around 500km.
The only tools required are: 14mm socket or spanner (to remove tappet cover nuts) Feeler guages 12mm ring spanner Medium sized flat head screw driver
You can also get proper valve adjustment tools which are basically the ring spanner and screw driver combined in one unit. They are no way manditory, but do make the job a lot easier. Here is one pictured below. Image:Tools.jpg
Article by Taz_Rx
