Tech:Engine/K Series/Carburettor
Revision as of 11:40, 8 July 2005 by MedicineMan (talk | contribs)
Stock
All stock units are Aisan-manufactured dual-throat single-choke downdraft-type carburettors.
  • 21/24 mm for single carb
  • 20/22 mm for twincarb motors (3K-B, 3K-D).
Jet sizes are:
  • 0.99/1.75 mm for single carbs
  • 0.84/1.40 mm for twincarbs.
Aftermarket
  • 130 mains
  • 170 air jets
  • 50 idle
and take it from there.
  • Weber 32/26 DFV (aka Holley 5200)
  • Holley 180
  • Weber 32/34 DMTT
  • Dellorto DHLA40 or Weber DCOE40 in single or twin configuration
  • Dellorto DHLA45 or Weber DCOE45 in single configuration.
Fitting aftermarket carburettors
  • Celica motors (18R, 2T, 3T) which are still Aisan carbs.
  • Datsun L motors, apparently these Hitachi carbs are just as crap as Aisans.
  • Mazda Capella and other cars with Mazda piston motors (1300, 626, etc).
  • Holden Gemini Nikki carbs
I have heard mixed reports of these Nikki carbs, some people say they are the bee's knees, some people would rather bolt on a DGV. I have managed to score one, one day I'll kit it and let you know.
See Also
External Links
Rollaclub
