Tech:Engine/K Series/Gearboxes
Revision as of 12:55, 7 June 2008 by MedicineMan (talk | contribs)
T40/T50(Toyota Factory 4/5 Speed Manual)
The T50 gearbox is a lot stronger than the K50 gearbox and is a split casing design. You can still purchase close ratio gearsets for the T50 gearboxes through TRD. The T40 or T50 gearbox can be adapted to a K series motor with a K-T Bellhousing,
The K-T Bellhousing came in a few different forms.
1. Cable clutch K-T Bellhousing, Extremely rare, Easier to install in earlier KE Corollas as you don't need to install a hydraulic clutch.
2. Hydraulic clutch K-T Bellhousing, Rare, Requires hydraulic clutch setup to be installed. (Off KT174 5K T40)
3. TRD Upright bellhousing, Like the Holy Grail if you can find one, Cable clutch, Designed to allow for the positioning of an upright K motor. If you have one of these please send me some pictures so I can upload them here, Also your address would be great so I can come and steal it :)
The W50 gearbox will fit if you use a K-W bellhousing from a KR42 Townace.
