Tech:Engine/K Series/Gearboxes
T40/T50(Toyota Factory 4/5 Speed Manual)
The T50 gearbox is a lot stronger than the K50 gearbox and is a split casing design. You can still purchase close ratio gearsets for the T50 gearboxes through TRD. The T40 or T50 gearbox can be adapted to a K series motor with a K-T Bellhousing,
The K-T Bellhousing came in a few different forms.
1. Cable clutch K-T Bellhousing, Extremely rare, Easier to install in earlier KE Corollas as you don't need to install a hydraulic clutch.
2. Hydraulic clutch K-T Bellhousing, Rare, Requires hydraulic clutch setup to be installed. (Off KT174 5K T40)
The W50 gearbox will fit if you use a K-W bellhousing from a KR42 Townace.
