KE70 Dash Cluster (AUS)
Revision as of 07:10, 25 April 2008 by MedicineMan (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Plug 1 Colour Function
Black/Orange Ignition Switched 12v Yellow Charge Light (To Frame) Yellow/Black Oil Pressure Light (To Frame) Red/Blue Ignition Switched 12v Red/White Brake Light (To Frame) Red/White Park Brake Light (To Frame) Yellow/Blue Fuel Light (To Frame) Black Tacho/IG- (Ignition Coil Negative)
Plug 2 Colour Function
Green Dash Cluster Illumination (Frame Return) Green Dash Cluster Illumination 12v Green/Black Left Indicator Light 12v Green/Yellow Right Indicator Light 12v Yellow/Red Fuel level sender (Resistance To Frame) Yellow/Green Engine Temp Sender (Resistance To frame)
Plug 3 Colour Function
White/Black Frame Return Red/Blue High Beam Light Red/Green Battery Constant 12v (B+) Pink/Blue Accessories Switched 12v
