Tech:Electrical/Starter Motor/Principles
Revision as of 05:18, 20 April 2008 by MedicineMan (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Principles
When current flows in a conductor, A magnetic field is generated in the direction shown in the illustration below in accordance with Ampere's rule of the right-hand screw.
Insert Image Here
If the conductor is placed between the North and South poles of a permanent magnet, The lines of magnetic force generated by electric current in the conductor and lines of magnetic force from the permanent magnet interfere with each other, Causing the magnetic flux to increase in the bottom of the conductor and to decrease in the top of the conductor. We can think of magnetic flux as a rubber band that has been stretched. Thus, The magnetic flux, The force which is tending to pull in a straight line, Is stronger at the bottom the conductor. The effect of this is that the conductor is subjected to a force which tends to push it upward (Flemming's left-hand rule).
Insert image here.
