Main Page Old
Welcome to the Rollaclub FAQ
Further Discussion of any articles here may be made on the: Old Corollas Yahoo Group and Rollaclub Messageboard
Tech
Engine
K Series
General Information
Blocks
Camshaft
Carburettor
Electronic Fuel Injection
Emissions System
Exhaust
Flywheel
Fuel Filter
Fuel Pump
Heads
How to build a tough K motor
How To Fix K Motor Oil Leaks (Problems And Cures)
KE1x Series K Engine Specific Info
Mounts
Oil Pump
Sump
Torque Settings
TRD Uprite Kit
What is a fuel solenoid?
K (1077cc)
2K (993cc)
3K (1166cc)
4K (1290cc)
4K-C Emission System Diagram
5K (1496cc)
7K (1812cc)
7K-E ECU
A Series
A-Series Engine FAQ
Alternator Wiring Diagram
Blocks
Converting to RWD
Crossmembers
ECU Pinouts
Electronic 4AC dizzy
External Thermostat
Gearboxes
Heads
Injectors
Internals
Rear Water Outlet
Rebuilding Your 4AG(Z)E
Replacing Your Timing Belt
Toyota Part Numbers
What Is TVIS?
Wiring Diagrams
S Series
Blocks
Head
EFI
Converting to RWD
T Series
Blocks
Gearboxes
E Series
Blocks
Fuel System
EFI
Fuel
Drivetrain
Bellhousing
Clutch
Automatic Gearbox
Manual Gearbox
Tailshaft
Differential Gears
Differential Housing
Axles
Suspension
KE1x Suspension Help
Rear Leaf Springs
Stud Pattern
Brakes
Front Disc Brakes
Rear Disc Brakes
Electrical
Alternator
Distributor
Relays
Starter Motor
Tachometer
Emission Systems
Emission System Abbreviations
Emission System Components
Reference Material
Corolla Model Numbers
Books
Codes - Engine, Body, Axle
Service
Torque Specs
Maintenance
Body
Engine
Suspension
Upgrades
KE70 K50 into 3K powered KE20
Nikki carb onto K motor
Sigma Control Arms
History
The '60s
The '70s
The '80s
The '90s
Racing
Related
Car Movies
