Tech:Engine/K Series/Carburettor
Revision as of 15:56, 27 January 2008 by MedicineMan (talk | contribs)
Stock
All stock units are Aisan-manufactured dual-throat single-choke downdraft-type carburettors.
  • 21/24 mm for single carb
  • 20/22 mm for twincarb motors (3K-B, 3K-D).
Jet sizes are:
  • 0.99/1.75 mm for single carbs
  • 0.84/1.40 mm for twincarbs.
Aftermarket
  • 130 mains
  • 170 air jets
  • 50 idle
and take it from there.
  • Weber 32/26 DFV (aka Holley 5200)
  • Holley 180
  • Weber 32/34 DMTT
  • Dellorto DHLA40 or Weber DCOE40 in single or twin configuration
  • Dellorto DHLA45 or Weber DCOE45 in single configuration.
Fitting aftermarket carburettors
  • Celica motors (18R, 2T, 3T) which are still Aisan carbs.
  • Datsun L motors, apparently these Hitachi carbs are just as crap as Aisans.
  • Mazda Capella and other cars with Mazda piston motors (1300, 626, etc).
  • Holden Gemini Nikki carbs
I have heard mixed reports of these Nikki carbs, some people say they are the bee's knees, some people would rather bolt on a DGV. I have managed to score one, one day I'll kit it and let you know.
Sidedraft
New manifolds can be purchased to adapt sidedraft carbs to a K motor, Available from such places as Repco (Made by Redline and Lynx). Also you can use a Redline linkage kit which can be purchased new as well. The bolt patterns are the same for Weber/Dellorto/Solex side-draft carbs. A new manifold like my Redline one will have to be machined to fit with the extractors. Make sure you have extractors before fitting twincarbs or you will get inlet reversion. (See also - http://www.rollaclub.com/board/index.php?showtopic=10634&hl= Twin Carb Linkage Discussion On Forum)
SU Sidedraft
LynxCorp (Australia) Manufacture a bolt-on SU Manifold for the K series engines.
This allows 2 x SU style carbs to be bolted onto your K engine.
Part number is M-117
RRP is about AU$220.00
Previous, more detailed discussion on the messageboard can be found here
Apparently lynx no longer manufacturers these manifolds and has run out of stock making them a hot item when for sale.
The general consensus is that 1.5" SUs are more preferable to the 1.75 on lower capacity K motors. More information here: http://www.rollaclub.com/board/index.php?showtopic=15069
Dellorto / Mikuni Solex / Weber Sidedraft
Redline Manufacture a bolt-on manifold for the K series engines.
There are 2 different versions to suit either a single or dual carbs.
Part number for single carb manifold is 12-3112
Part number for dual carb manifold is 12-3062
See Also
External Links
Rollaclub
