Tech:Engine/A Series/Alternator Wiring Diagram
Revision as of 08:24, 24 March 2007 by MedicineMan (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Here are a few diagrams to help you understand the alternator wiring on your 4AGE when doing your engine conversion. They are internally regulated so if you are converting an AE71 you can remove the external regulator.
( B+ ) - Battery Post - Heavy gauge wire that connects to the battery.
( S ) - Sense - Used to sense voltage across the battery to prevent overcharging.
( L / D+ ) - Lamp - Alternator charge Lamp (Turns off when alternator starts charging).
( IG ) - Ignition - 12V Ignition Switched Source
Article by Medicine_Man
