Front Disc Brakes
General Information
All discs are all interchangeable (the Corolla hubs are the same except for wheel stud pattern), or if you change hubs as well, KE1x and 2x have smaller inner wheel bearings than the later cars. If changing from smaller disc to larger disc, you will need caliper mounts from a KE30 or KE55, as KE70 caliper plates have a different stud pattern. On most KE1x/2x cars, you will have to drill a tap the caliper mounting plates to M10x1.25, as the later model plates use larger bolt holes to mount to the strut. 70560028268113791163428
Go Buy Reductil Online now!
Go Buy Zyban Online now! Go Buy Plavix Online now! Go Buy Norvasc Online now! Go Buy Ambien Online now! Go Buy Zyrtec Online now!
40764636916
Anal Creampie,
Ass Creampie, Blonde Creampie, Teen Anal Creampie, Teen Creampie, Teenie Creampie, Young Creampie
Forced To Prostitute |
Cuties In Stockings | 2 Crazy Bitches | Moms Assistant | Girls Got Cream | Rave Glory Hole | Young Throats | Shemales Fuck Girls | Creampie Mania | Drunk Glory Hole | Fuck This Tranny | Lick Sonic | Girls For Matures | Cream In Teen | Quickie Fuck | Shemales Fuck Shemales | Sleeping Bitch | Shemales Fuck Guys | Real Drunken Girls | Cum Filled Throat | Vip Tranny | Nubile Ones | Mature Debutants | [http://webtest-community.canoo.com/wiki/space/huynani/blackseducer.h
Upgrades for KE1x
Directions For Fitting:
17. Bleed the brake system.
Upgrades for KE3x, 5x, 7x
  • Corona XT130/RT132 struts and brakes. These come in 2 flavours - either single pot or twin pot. For some photos, look at Corona front brake upgrade photos on Planet FookStar
  • The much-talked-about Peugeot 604 discs, Hilux/Landcruiser calipers, on XT130/RT132 struts. Effective, but rather heavy. For some photos, look at Pug/Landcruiser brake upgrade on Planet FookStar
  • RX7 calipers and some sort of disc (?)
  • Vented AE86 struts and brakes. This isn't really much of an upgrade as the AE86 brakes aren't overly big, and neither are the calipers, but it does help cooling.
  • Magna discs, Commodore calipers (?)
  • Silvia/200sx struts, brakes. This is apparently a fairly straightforward swap. For some photos, look at Craig's Datsun 1200 on Planet FookStar
  • If using Silvia/200sx struts, then the many many brake upgrade options from there (Skyline etc)
And here are some photos:
Back to Brakes
Rollaclub
