Tech:Engine/K Series/How to build a tough K motor
by Super Jamie <[email protected]>
These are my opinions, observations and conclusions on how to build a tough K motor. Some people might tell you i'm full of crap, some people might agree wholeheartedly. If you think you can do better, and you want to prove me wrong with proof of back-to-back comparisons, then please by all means do, everyone likes to learn something new or how to do something better.
All prices discussed are in Australian dollars, all laws spoken of refer to Australian Design Rules. If you're overseas, check with your local registration/law guys before doing anything.
By no means do you have to do everything listed on this page. Your engine will "work" with just some things, in that it will motivat the car forward, and be better than stock. It might not be at its' total full potential, but cheap fun is what this guide is all about. Besides, it's kindof unsatisfying to be at the point where you can't make any more power, trust me. You do need to do some things, and I will tell you which as I progress.
In one paragraph
Don't spend heaps of money, it's just a crappy old K motor. Balance everything if you can afford it. Use a 20-60 cam in a 3K, 25-65 in a 4K, 4K is better. Run 0.400" valvelift, fit heavy duty springs if you don't want the stock ones to wear out in a couple of years, use 4K valve gear. Shim the oil pump spring 3mm for more oil pressure. Run between stock and 10:1 compression. Get the distributor recurved. Fit extractors and an exhaust larger than 1.5" but not larger than 2". Obviously, fit a new timing chain and tensioner, if not a whole gasket kit. Put something better than the stock carby on, but not too big. Don't rev it past 8 grand.
Reasons to use a K motor
DO use a K motor if you are on a budget. These can be very cheap motors to modify for noticeable reward, and also to replace if you stuff up and kill it. That's the best thing about them, parts are cheap, and spare engines and parts can commonly be had for very little or free. However like anything, they can be expensive as well, if you let them. Keep it in perspective.
DO use a K motor if you can't be bothered engineering your car. Want 100hp for as cheap as possible? Don't want to spend the money on upgrading the brakes, wheels and tyres? Want to just bolt something in and do burnouts? Technically, there's a clause in the ADRs that says if you sufficiently increase the power of an engine to warrant it, you need to upgrade other relevant safety systems, but that doesn't stop your car passing rego. This was one motivation for me.
DO use a K motor for something different. At the time I did my motor, it seemed everyone was doing a 4age transplant, or rattling off numbers numbers letters of all these high powered engines which they see in car magazines and will never buy. Nobody remembered the poor old stock K engine. It's also pretty cool to have a noisy lumpy sounding engine, and you can really impress people when you tell them a naturally aspirated 1300cc did THAT!
DO use a K motor if you just want something that bolts in. I can't weld custom engine mounts either, so I went with the easy solution. I also couldn't be arsed converting my car to an efi fuel system, wiring in a computer and all that jazz. I also like the self-tuneability of carbs and a distributor.
DON'T use a K motor if you have plenty of money to spend. If you want the best engine for your corolla and you'll spend more than a grand on it, forget a K motor. Drop in a 4age or some other efi thing, possibly even force inducted if you want to, and you can drive it without crashing it. Take it from someone who's built a $2000 4K, I could have got the same thing (minus the lumpy idle) by buying a $850 4AGE, with alot of potential for more power as well.
DON'T use a K motor if you want to beat things on the street. About the best you'll manage is flogging crappy old Lasers and Magnas, and a stock Commodore up till about 100km/h. All your mates probably have really fast cars, and if you want one too, be prepared to either spend alot of money on your corolla, or just buy a car that's fast in the first place. Budget modifed Corollas are quick, not fast.
DON'T use a K motor if you want to "drift". If you think you have the "mad skillz" like Fujiwara Takumi, or you are building a "drift pig" corolla because you're a P-plater driving professional, then forget a K motor. The best power you'll reliably get out of one cheaply is less than a bigport 4AGE makes, and nobody drifts with them.
Starting Point
Block
Your main choices are usually either a 3K, 4K or 5K. The 3K is easy because it might be in the car now, but really they're too small to make much power, because of the different stroke. About the best you can do is have a little torquey 1200 which peaks at 6500rpm, or a revvy little engine which makes nothing down low. The extra couple of hundred dollars a 4K wrecker motor costs (and really, if you hang around Corolla people long enough you'll pick one up very cheap or free) is money well spent. However, if you do modify a 3K, about the only thing that matters is the camshaft selection, which I will cover later.
The increased stroke of a 4K and the fact that it's a very in-square motor (having 75*73 bore*stroke) makes it ideal for shifting a fairly decent amount of air. A 5K can basically be treated like an oversized 4K, which is handy because extra torque is also very nice and helps make that little bit more top end. However, 5Ks are still quite expensive ($550) from wreckers, and still a little hard to find second hand for a decent price (under $300). If you can get one, go for it, if not, a 4K is almost as good for a cheap thrash motor.
Apparently the design of the blocks suffer from harmonics above 8000rpm and crack with stunning predictability. My 4K has hit 8500rpm a fair few times and it's all good every now and then, but don't hold it there or rev it that hard every day. There are also two different types of 4K block, one has three very noticeable ribs below the manifold side welsch plugs, just like a 3K if you can have a look at one. The other has small ribs and a large flat area. The unribbed block is far weaker, if you have one of them, scrap it.
Head
People go on and on about how good 3K bigport heads are. Whatever. A bigport is also well over 30 years old, and probably has a fair bit of corrosion around the water jackets, it might even have developed a crack, will strip at least one manifold or rocker thread, and probably has a few helicoils in it. They also have crappy valve retainers and stem seals, which you need to change to later 4K gear when you make power.
With the amount of money you'll spend having an old late 1960s 3K head reconditioned to a working state, you could have taken a 20 yearold 4K-C head which works perfectly fine, is less prone to cracking, and had a port job done on it which is better than a bigport casting. Don't waste your time searching high and low for the elusive mystical 3K bigport, I have two of them and take it from me, they're not that bloody good.
Bottom End Mods
Block Prep
These are pretty well put together little engines. 5 bolt mains and rod bolts as big as a 350 chev. While you've got the thing apart, change all the welsch plugs and take the studs out of the timing cover and rear main carrier and use bolts, it makes servicing the engine (if you ever need to change the timing chain, for instance) so much easier. Check the bearings if you like, but if the engine was working before and hasn't done a huge abount of mileage, you should be right to just slap it back together with a new bearing and seal kit. But it needs new stuff, it needs new stuff. Running bearings one size over isn't that bad, but two sizes and I'd scrap the crank and find another one.
Balancing
One thing I will suggest, if you're going to rev an engine high (8000rpm+) then get the internals balanced. Not only will it prevent the engine from fighting against its' own intertial mass, hence making more power and having less wear, it will also transfer less vibration to the rest of the drivetrain, so the weak little K gearbox will last longer, especially at high speed. Get anything that moves balanced - crank, pulley, flywheel, rods and pistons. They don't need to be balanced together. A balanced component has equal rotating mass on it's own, as well as with other components. Balancing should set you back between $160 and $250.
Pistons
One good thing about 3Ks is that they have japanese Toyota pistons in them. Aussie-assembled 4K motors have these crappy aftermarket Repco pistons, which will crack. You can tell by looking up the skirt of the piston, one side will always have the TEP logo, the other side will have REPCO embossed in it further up on Aussie pistons. If you want aftermarket stuff, standard ACL replacements are just fine, they're actually far better quality metal than the stock pistons ever were. Retail on my set of 060 3K/4K pistons was about $390, but I paid cost which was $160, so you've got a fair bit to bargain for discount if you buy new stuff.
Nobody makes forgies specifically for a K motor, but there ARE motorbike pistons that fit, but you'll have to look all the specs up you need in the freely available ACL catalog, then trawl a bike piston catalog till you find a match. Serco, the Australian Wiseco distributor, offered to have me custom billet slugs made up for the bargain price of US$2000. No thanks.
There are also TOSCO (1960s TRD) 3K/4K pistons available, super duper rare and impossible to find, which are oversize up to 0.160". You might hear Bill Sherwood talk about the set he's got. Apart from the fact you'll have little bore wall left and will probably crack the block the first time you rev it hard, these are full race pistons with one compression ring, one oil ring and no thrust skirts, so they're near useless in a street motor which you want to last more than the run-in period. Don't bother.
Lightened Flywheel
Of all the things you can do to a motor besides air supply and camshaft, this probably changes its' characteristics the most. I had my stock 4K flywheel machined down to 7kg (I have no idea what they are stock) and I like the way the engine builds revs quickly. People say you lose torque, like the ability to climb hills, with a lightened flywheel. But the engine also has less mass to spin, so you transmit more power to the wheels. You can make a K motor pretty torquey anyway, I say it's worth it. Doing this will also make your idle more lumpy. Machining of my flywheel cost me $80.
Companies will also make you a custom alloy flywheel, you supply them a stock one, and they make an alloy center with a clutch face, and press the stock ring gear onto it from your flywheel. These things can get down to 4kg, and you'd probably need a fairly high idle (1200rpm+). Expect about $600, though we got down to $400 with a 5 or more group buy. Jun make two billet alloy flywheels for 4K motors, one is 3.7kg, one is 3.4kg. They're $990 and $1100 respectively through Speedworks Auto in Perth.
Camshaft
This is possibly the most important choice of parts to make. You modify the cam by having it ground, the diameter of the base circle is reduced to increase lift at the lobe. The only thing which really affects the cam profile you choose is the stroke of the crank. A cam grind plus lifter facing (so the lifters wear evenly with the new lobes) should cost about $130.
The stock cam profile is 16-50 (246 degrees adv dur), and Sprinter (3K-B) cams are 18-58 (256 degrees adv dur). The stock cam runs 0.338" inlet valve lift, and 0.356" exhaust valve lift. I can't find anything to say a Sprinter cam has more lift. Ideally you should be running at least 0.400" lift (the limit of stock springs), I've seen cams which run up to 0.432" lift without having to counterbore the springs into the head so they don't bind.
As I'll mention later, if you change to a cam any bigger than about 260 degrees advertised duration, you're going to need extractors and an exhaust, as the extra air the engine is moving is too much for the stock exhaust manifold, and you get inlet reversion, where the air-fuel fixture gets pulsed back and comes out the throat of the carby in a fine mist.
3K
Because the 3K is so oversquare (bore is larger than stroke), there's a limit to the amount of power it can make and still be driveable down low. As I've already said, a 3K is always going to be a compromise of top end or bottom end, when compared to the potential of the larger stroke 4K crank.
Personally, I think the best cam for a street driven 3K is a Tighe 112 (20-60, 260 degrees adv dur), it gives not too much loss of torque down low, and peak power at 6500rpm, just above stock and great for unbalanced bottom ends and stock valve springs. The sprinter cam isn't bad, but it's not that good either.
4K
This includes 5K as well, because there's no such thing as a 5K crank, they all have 4K stamped on them. A 4K has more stroke than a 3K, and can shift a noticeably larger amount of air. As an engine is basically an air pump which uses fuel to keep moving, the more air you can move, the more power you make. It's a very in-square motor (75*73 bore*stroke) so you can make torque and power at the same time. A 5K is basically a 4K with even more potential to shift air because of the larger 80.5mm bore, and it does make a difference.
Alot of people have favorite cams for the 4K, debate can get pretty intense, so I'll list all the common ones. The 20-60 described above is still fairly good, makes more torque than any other (useful) cam profile I can find, and still peaks at 6500rpm. My favorite is my CE701 (25-65 270 degrees adv dur, 0.398" lift) by Camshaft Engineering in Coorparoo, I think this gives a nice balance of LOTS of torque and good strong top end, with peak power at 7500rpm. My KE25 with this cam does over 200km/h and can drive up most hills in 5th. Tighe Cams do this profile too, the Tighe 113 has 0.400" lift, the Tighe 104 has 0.423" lift.
Rob Dixon's favorite cam is his custom Wade 169x (30-70, 280 degrees adv dur, 0.405" lift). This gives about the same horsepower as the above cam, but loses a bit of torque due to different valve timing. Stewart Ford's favorite cam is his Camtech 609 (33-64 72-32, 277/284 degrees adv dur, 0.435" lift) which is close to the other cams, but from what I can find, there's a small drop in both power and torque compared to the 25-65.
I really think a cam with anything over 270 degrees advertised duration is too big for a 4K crank.
Lifters
If you get a cam grind, get the lifters faced too. The lobes of the cam are always ground on an angle and the end of the lifter is a slight dome, so the lifter rotates whilst it is in contact with the cam, this promotes even wear of the cam and lifter together.
Only 5Ks run hydro lifters. All the V8 boys think solid lifters are the way to go for big power. Hydraulic lifters can "pump up" at high rpm, as they're not given time to drain properly, especially if you're running a thick oil. Hydro lifters are quieter, but run zero valve clearance so you can't tune the cooling of the exhaust valves with extra valve clearance, which may be a problem in a high-heat environment (such as a high compression motor). I'd change to solids.
To change to solids in a 5K, you can use Holden red motor lifters and Datsun 1200 pushrods, and you should have just enough adjustment thread in the rockers to be able to set a useable valve clearance.
Oil Pressure
Oil both lubricates and cools the engine, so it's pretty important stuff. An engine which is drawing more air into the cylinder (different carb or cam) or whose components are under more stress (increased compression & rpm) is placing an increased load on the oil to do both of its' tasks. Increasing oil pressure is the way to put reliability back into a modified motor.
Oil pressure in a K motor is increased by shimming the relief spring on the oil pump. Take the split pin end of the relief, and shim the spring about 2-3mm (use washers or a little nut, something metal) into the spring cup (not into the pump) and put it all back together.
Shimming the spring in the oil filter block does nothing but increase the pressure at which the oil filter bypass opens, hence possibly starving the engine of oil under extreme conditions. Early KE10 engines had no oil filter bypass, so everything went through the oil filter. Stewart uses one of these.
It has been said in the past that the limit of efficiency of the stock oil pump is about 60psi, anything over that is just needlessly fatiguing the pump. Mine's about 50psi with a 2mm nut on the relief spring. It's normal for it to fall down to 15-20psi at idle. You'll notice your oil pressure will drop 5-10 psi when your oil is a bit worn out.
Oil
I'm not going to discuss brand preferences here, rather viscosity and composition.
I've found that straight-weight, mineral based oils with no synthentic friction modifiers last longer in K motors. These are not a modern, tightly built engine, and they have alot of piston blowby which pollutes the oil pretty quickly. The rings also seem to float at about 6600rpm (factory redline), so your engine will be extra hard on oil if you're revving it to 8 grand. 30W is good for an old trusty motor, it lets the components move free enough but provies enough lubrication to allow the tappets to be whisper quiet. 50W or 60W if you have a tired old rattly donk that you want to get a couple more years out of.
I've found friction modified oils (eg: 20w50) to be of limited use in a K motor. Sure, they might provide a bit extra protection when cold, but they don't last anywhere NEAR as long as a straight mineral oil when you punish them.
If you have a tightly put together engine, you can run a thinner, synthetic friction modified oil if you like. I run semi-synthetic 15w40 in my engine. I've run straight 30W and a fully synthetic 5w50 as well. I find the 15w50 gives a good balance of lubrication (judging from the noise the tappets make) and less frictional losses. The engine revs noticeably slower with the straight 30W but you can't even hear the tappets. With the 5w50 in the sump, it literally can't wait to jump off the tacho, which is great but I couldn't stand the rattle of the valvetrain.
I don't really think additives do anything to help your engine, and in some cases can harm it if you put in the wrong thing, or mixture of things, so I don't use them.
Oil Filter
Me, I have an expensive engine, so I use a genuine oil filter. I recommend you do the same, even if your motor is stock. These are the only filter which has the non-flowback valve, so your engine makes some effort to retain oil pressure after the flow stops, which is good for cold starts.
As far as aftermarket filters go, my preference is with Ryco. They seem to have good flow and filtration qualities. I'm not a big fan of anything Valvoline, and they're what's commonly on the shelf at Supercheap. Fram filters are big in America, and have started to come out here in Australia as well. From what I've heard, they used to be great back in the 70s but quality has slipped as the company entered the 21st century.
Top End Mods
An engine is an air pump, the more air it moves, the more power you can make. The head is how the air gets inside the engine so there are alot of things which affect the power levels you can make. A full-house bottom end with a stock head is nowhere near its' full potential. A stock bottom end with a worked head will make more power any day (though may have reliability issues depending on what else you've done to the motor).
Compression
I wouldn't suggest running much over 10:1 in a K motor. The head design really isn't the best for promoting good combustion, and detonation sucks once it sets in. I run 10.2:1 in my motor, and it get piston shakes quite badly below 2500rpm, but I think that's more to do with my amateur head porting. One of the guys on toyotastarletracing had a 4K he didn't care about anymore, so for a laugh he shaved the head down to 11:1 and slapped it back on. He said it absolutely FLEW but didn't last very long. If you want to push the limits, work out what dynamic compression you're running and keep it below 8.4.
A good rule is to take the octane number of the fuel you'll be using, and divide it by 10. BP Ultimate has a RON of 98, so 9.8:1 is pretty ideal compression for an engine running on that. Standard unleaded is 91 RON, which is alot less compression. You can usually get away with deviating 0.2 to 0.3 compression points from this rule, if your head porting and fuel supply is up to scratch.
Head Porting
I'll write more on this at a later date, probably in its' own section. Basically, clean up the short radius, and keep it on the same radius point as the outer bowl wall. Taper the valve retainers, teardrop the bowl around them for good flow. Deshroud the valves and valve seats but retain as much quench area as possible. If you have stock-sized valves, leave the inlet port size stock, it's perfect for best airspeed. Anyone who tells you they've taken the inlet ports of their head out nice and big and has stock valves is an idiot. Oversizing the exhaust ports is probably a good idea, to create a kind of vacuum effect to suck more exhaust out of the cylinder, and more intake charge in its' place.
There is also usually a casting ridge just below the spark plugs, and it's a good idea to grind that ridge smooth to promote quicker oil flow back to the sump.
Valve Stems, Seals & Retainers
The valve seals and retainers on a 3K are a bit old and silly. They have an upside down cup on top of the valve, with an o-ring on top, and a quite tall valve stem, the combination of which is supposed to direct enough oil away from the stem to stop the inlet getting oily. The spring retainer sits in another groove below this cup. Unfortunately, if you have an engine with altered vacuum characteristics (ie: a camshaft) then you have the tendancy to suck oil into the inlet via the valve stems. The higher stem also stops you from running as much lift as you can with newer stuff.
Later heads, 4K onwards, have a much better system. The stem is shorter and hence allows for more lift, and has a clip-on rubber seal which restricts the amount of oil that lubricates the valve quite well. The retainer is at the very top of the valve. To change over, you need to change the lot - stems, valves, retainers and seals - and re-cut the valve seats to suit the new valves.
Valve Seats
Valve seats made after February 1972 are made of hardened steel and are fine for use with unleaded petrol. Toyota Corporate themselves told me this.
It is beneficial to airflow to have mutliple angles on the valve seats. The stock seats are just cut at one angle, so the air deflects off to the sides of the chamber, the sudden change of direction also causes it to lose velocity, which is something you don't want. Getting a three-angle valve job lets the air gradually curve around into the combustion chamber, retaining velocity for better air movement, and putting the fuel around the spark plug where it should be.
You can get as many angles cut into the seats as you have the money for, or time if you're doing it yourself. I've heard of some perfectionists who cut 7 angle valve seats, almost like the seats are round. I think it's alot of work for a diminishing return, 3 angles is fine.
Valve Springs
The most lift you can run with stock valve springs is about 0.400", after that you need heavy duty springs. Whilst stock springs will definately hit 8000rpm without a problem, they'll de-tension fairly quickly (say within a couple of years?) and you'll need to replace them more often than a set of heavy springs. My springs were $110, compared to $80 for stock springs, I think it's worth the upgrade if you have larger-than-stock lift and revs planned.
What height aftermarket springs bind at depends on the thickness of the coil and how many of them there are. If in doubt, assemble and measure. Rob's head uses heavy Holden 202 red motor springs, but you need to bore the spring seat down more into the head so these don't bind.
The stock spring seat pressure is 70lb (77lb for bigport Sprinter heads). From memory, Stewart's running some springs which fit and are 120lb. Anything between those two numbers should be fine.
Bigger Valves
3K and 4K engines will benefit from larger valves (and the accompanying larger ports that accompany these), and they're definately THE big restriction point on 5K motors. Realistically, any valve can be used as long as it doesn't shroud too much against the edges of the combustion chamber (hence, running oversize pistons enables you to run bigger valves more usefully than stock bore size does). This is likely to be a very expensive head job ($600+) and is beyond the scope of this article. David Vizard has some good rules for calculating ideal port size based on valve size, buy his books.
Rockers and Posts
Understand that the rocker pivots on an axis, and the valve moves vertically, hence the rocker must "wipe" across the face of the valve stem at some point whilst it moves the valve down. It's better to have this lateral movement at lower lift, as it gives less wear to the valve stem and puts less strain on the whole lot. You accomplish this by lowering the axis upon which the rockers move, which is supported by the rocker posts.
Toyota had it pretty well setup from factory, so a good rule is to have the rocker posts accurately machined down by the amount of valvelift you have added to the engine. Stock lift is about 0.340"/0.350" (inlet/exhaust) so say you're running 0.400" lift, you need to have the rocker posts machined down about 0.060".
There are two types of rocker post, early alloy and later cast iron. The cast ones are better, as the suffer less from thermal expansion (it gets pretty hot in your engine you know) and when the posts expand, they raise the axis upon which the rockers pivot, hence open up the valve clearance more, this is bad.
Changing from bolts to studs and nuts for the rocker posts is also a good idea, make sure you use high tension stuff.
Valve Clearance
Valve clearance is there to allow the valves to cool in between combustion events (spark), and to make sure the valve closes properly and contains the combustion explosion. You need to cool the valves a little bit, the exhaust valve moreso than the inlet, as it's what sees the most heat as spent burnt gases go past it into the exhaust port. Run too little clearance and you'll cause the valve to "weld" a little bit to its' seat every time it closes, and then take seat metal off again when it opens. Do this enough times and you burn out the valve seat and need the head reconditioned. However, by running less clearance, the valve stays open for that little but longer, and you get more air in and out of the motor, and make more power. Run too much clearance and your motor sounds like a diesel and loses power, so it's better to err on the side of caution.
The stock valve clearance (0.008" inlet / 0.012" exhaust, warm) is pretty good for any of the cams I've listed above, they're well-sized street cams, not really wild top heavy race cams that require super high compression to work, so don't be afraid to close the valves up a bit from the suggestions of the cam grinder, which will usually say between 0.010" and 0.014". There are a few ways to set your valve clearances:
Yellow Book Method
This is from the factory 3K/4K/5K engine manual, aka The Yellow Books. It's the quick and lazy method.
Set engine to #1 TDC. Crank pulley timing mark should be on 0, distributor rotor should be pointing towards spark plug 1 or 2. Set tappets (counting from the front) 1, 2, 3 and 5. Rotate engine 360 degrees, crank pulley to 0 again, distributor rotor turned 180 degrees. Set tappets 4, 6, 7 and 8.
Nine Method
I've never really gotten into doing this, takes too much time and maths for my liking :P Rotate the engine through its' range of movement, as one valve is "on the rock" of its' max lift, subtract the valve number from 9 and that's the tappet you should be setting. For example, if #8 valve is open, set clearance on valve #1. If valve #7 is open, set clearance on #2. And so on.
Stewart uses this method, and rotates the camshaft through its entire base circle and sets the clearance at the highest point. Which is a pretty good idea, as it compensates for the possiblity that the base circle has been ground unevenly, and allows you to run the proper valve clearance that you want to run, instead of something that may be a few thou larger in reality.
Degreeing In a Cam
This gives the most accurate method of setting the cam timing, regardless of what clearance you're running. If doing this, it might pay to check the clearance at the base circle instead it winds up being too big/small for your liking. To degree in a cam, you'll need the specs of your cam, and to print off a degree wheel about the same diameter as the K motor crank pulley, and stick the degrees onto the pulley. Alternatively, you can buy a degree wheel at a speed shop.
A 25-65 cam opens the inlet 25 degrees before top dead center (BTDC), closes the inlet valve 65 degrees after bottom dead center (ABDC), opens the exhaust valve 65 degrees before bottom dead center (BBDC) and closes the exhaust valve 25 degrees after top dead center (ATDC). Start at 0 degrees TDC and rotate the engine through its' range of movement. When you get to the timing when a valve should open or close, based on the position of the piston in relation to TDC or BDC, set the clearance on that valve to 0.001".
Spark Plugs
Stock spark plugs are NGK BP6ES or Denso W16EP. These are what you should use in a stock engine.
I find with my higher compression and what not, my engine gets some wierd thermal thing going with stock heat range plugs, and my exhaust tappets would unwind and over double in clearance, over a driving distance of about 500km. So I've changed to one step colder NGK BP5EY (aka Denso W20EP) and it fixed up.
As an engine gets really old and starts blowing a bit of smoke, you might even find a hotter plug (NGK BP7ES) gives it a bit of go back, however do realise that the bottom end is approaching its' wear limit and it's time to start thinking about a refresh or new motor.
