Tech:Engine/K Series/Carburettor
Stock Carbys
All stock units are Aisan-manufactured dual-throat single-choke downdraft-type carburettors.
- 21/24 mm for single carb
- 20/22 mm for twincarb motors (3K-B, 3K-D).
Jet sizes are:
- 0.99/1.75 mm for single carbs
- 0.84/1.40 mm for twincarbs.
Aftermarket
- 130 mains
- 170 air jets
- 50 idle
and take it from there.
- Weber 32/26 DFV (aka Holley 5200)
- Holley 180
- Weber 32/34 DMTT
- Dellorto DHLA40 or Weber DCOE40 in single or twin configuration
- Dellorto DHLA45 or Weber DCOE45 in single configuration.
Fitting aftermarket carburettors
- Celica motors (18R, 2T, 3T) which are still Aisan carbs.
- Datsun L motors, apparently these Hitachi carbs are just as crap as Aisans.
- Mazda Capella and other cars with Mazda piston motors (1300, 626, etc).
I have heard mixed reports of these Nikki carbs, some people say they are the bee's knees, some people would rather bolt on a DGV. I have managed to score one, one day I'll kit it and let you know.
See Also
Back to Fuel System
