Tech:Engine/K Series/Fuel Filter
Revision as of 10:44, 26 April 2005 by Super Jamie (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Any boring old plastic $1 fuel filter will do for one of these motors. Place it before the fuel pump. Part number is Z14.
If you want your engine bay to look trick, you can buy a glass fuel filter, usually with chromed or polished fittings, and a replaceable element.
KE10s had a glass fuel filter with a washable element. I'm not sure if these elements are available from Toyota still?
If you have decent carbs and are sucking alot of fuel, you're going to want a decent fuel filter. EFI filter Z110 (I think) has 8mm fittings but flows ALOT and would be great for high performance applications.
Back to Fuel System
Rollaclub
