Help:Introduction to WikiText
Revision as of 01:12, 22 May 2005 by Wyldephyre (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
In Wikis, proper markup of text plays an important role; It is not merely cosmetic. Headings are used to generate Tables of Contents, and links within the wiki, and links to external sites are diffent.
Organisation
An article in MediaWiki is analogous to a webpage. Articles may belong in one more categories. Categories, in turn, maybe subcategories themselves. Within an article, sections are distinguished be headings.
Categories
Categories are assigned to a page like this:
[[Category: (Name of category)]]
So for example, to put an article in the Fuel System Category, we use:
[[Category:Fuel System]]
Notes
  • It is convention to put category tags at the bottom of each article.
  • An article may belong in more than one category.
  • You link to a category page like this: [[:Category:Fuel System]]. (Note the extra : before Category.
  • Adding a category tag to a category page makes it a subcategory.
Headings
= Heading One =
== Heading Two ==
=== Heading Three ===
until
====== Heading Six ===
For example, the article about Carburettors has the following sections:
  • Stock Carbys
  • Aftermarket
    • Fitting aftermarket carburettors
  • See Also
This would be marked up as:
= Stock =
= Aftermarket =
== Fitting aftermarket caburettors ==
= See Also
Notes
  • Headings are used to generate the Table of Contents at the top of each page.
  • If you do not want a heading to appear in the TOC, use the corresponding html tag instead of the ='s.
Links
Tables
Images and Media
See Also
