Tech:Engine/K Series/Carburettor
Revision as of 10:40, 26 April 2005 by Super Jamie (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
All stock units are Aisan-manufactured dual-throat single-choke downdraft-type carburettors.
All throat sizes are 27/27 mm. 3K and 4K venturi diameters are 21/24 mm for single carb, and 20/22 mm for twincarb motors (3K-B, 3K-D). Jet sizes are 0.99/1.75 mm for single carbs, and 0.84/1.40 mm for twincarbs. Throttle is operated via accelerator cable with the progressive secondary throat operating on a mechanical linkage, although there is a weighted vaccuum-style "flapper" butterfly in the secondary throat as well. These carbs flow around 150CFM.
Some carbs have an ignition-operated solenoid switch to prevent run-on (dieselling), I suspect that this came in around 1975 (with the KE30), however some later model cars have been released from the factory with no solenoid? I have found a paragraph in a Toyota workshop manual that suggests this is part of the -C motor emissions system.
These original carbs are quite poor, having very little mixture adjustment, and it would seem they have poor fuel atomization qualities too (whoever heard of a standard carb running RICH on a worked 4K?). There's isn't really much you can do as far as modification is concerned. An open-side design air filter, or Ram-Flo, will help throttle response tremendously compared to the stock snorkel-type filter housing. It has been suggested that jamming the secondary throat "flapper" butterfly open (put a spring on the weight arm or something) could help, but just seems to reduce throttle response at low RPM and make the car more noisy up high, maybe with some slight midrange improvement in power.
Therefore, one of the easiest mods for these cars is to change the carby!
A Weber 32/36 DGV is the most common aftermarket downdraft around. Usually you'll need to jet down a carburettor like this, unless someone has already done the work for you, or you have a fairly modified engine. For a 3K/4K, start at around 130 mains, 170 air jets, 50 idle and take it from there. Basic tuning tips: If the car "stumbles" forward but revs eventually climb, you're running too rich. If the car just cuts and dies, you're running too lean.
Other carbs suitable for these motors include: Weber 32/26 DFV (aka Holley 5200), Holley 180, Weber 32/34 DMTT, Dellorto DHLA40 or Weber DCOE40 in single or twin configuration, Dellorto DHLA45 or Weber DCOE45 in single configuration. One of the best carbs I think you can find for one of these is a Weber 28/36 DCD from a Mk1 GT Ford Cortina. You probably wouldn't want to go much bigger than that. I also have a Nikki 28/32 off a Mazda of some kind that I'd like to try out.
- Celica motors (18R, 2T, 3T) which are still Aisan carbs.
- Datsun L motors, apparently these Hitachi carbs are just as crap as Aisans.
- Mazda Capella and other cars with Mazda piston motors (1300, 626, etc). I have heard mixed reports of these Nikki carbs, some people say they are the bee's knees, some people would rather bolt on a DGV. I have managed to score one, one day I'll kit it and let you know.
Back to Fuel System
Rollaclub
