very attentive fookie, it looks like there's some sort of clear plastic over them tho? like a dome?
my gauges are green too. i could get the dremel out and remove the colored plastic inserts around the lamps, but a) i'm too lazy and b) it would make the posts for the center riser bits wobbly and i don't want to hack up my dash. admittedly that could be fixed with araldyte, but see point a) :D
very good fook.....i was going to see if anyone noticed.....yes the domed (boobies my brother called them) stock lenses are gone and i replaced them with flat plastic, the plastic is very clear to see through.....you need bendable stuff though so you can get them in and out.....
  • 3 years later...
