eh yguys, i have been on these forums only recently, and thought i might make a bit of a contributions to the forums ;)
I was unsure of what the diferent model designaions where, and what they looked like, so i did a little research, and tought that what i came across, wight help a few others that may be in my position :( :(
KE1x
1966-1969
The initial car, the KE1x series was small, with a 90 in (2286 mm) wheelbase, and used a 4-speed manual transmission or 2 speed automatic transmission, with rear wheel drive.
The suspension in front was MacPherson struts supported by a transverse leaf spring beneath the engine crossmember, with leaf springs connected to a solid axle in back.
Japanese engines:
1K — 1.1 L (1077 cc) I4, 2-valve OHV, carb, 60 hp (56 kW)
3K — 1.2 L (1166 cc) I4, 2-valve OHV, carb, 55 hp (41 kW)
JPN-market chassis:
KE-10/11 — Sedan, 2-door/4-door
KE-15 — Hardtop coupe
KE-16 — Wagon, 2-door
KE2x
1970-1978
The KE26 wagon and van were still marketed in Japan after the 30-series was introduced.
Japanese engines:
2T-C — 1.6 L (1588 cc) I4, 2-valve OHV, carb, 75 hp (56 kW)
3K-C — 1.2 L (1166 cc) I4, 2-valve OHV, carb, 55 hp (41 kW)
JPN-market chassis:
KE-20 — Sedan, 2-door/4-door (Std, DX, Hi-DX)
KE-25 — Hardtop coupe (DX, SL, SR)
KE-26 — Wagon, 3-door Panelvan, 3-door
KE-27 — Hardtop coupe (Levin/Trueno)(also known as TE27) (scrap that, apparently, a KE27 is a KE55 dressed up to lok like a TE27, who would have guessed?? :lock: )
KE3x, KE4x, KE5x
1974-1981
The 3K engine were used in certain markets, while most Japanese and American models had the stronger 2T engine. A "Toyoglide" 2/3-speed automatic transmission was added as well as a four-speed and five-speed manual tranmission, driving to the rear wheels. A three-door "liftback" (KE50) and sport coupe (KE51) was added in 1976. The KE40 and KE60 series were assigned to the Sprinter variants.
Japanese engines:
2T-G — 1.6 L (1588 cc) I4, 8-valve DOHC, carb, 124 hp (93 kW)
4K-C — 1.3 L (don't know cc) I4, 2-valve? OHV, carb, not sure of power rating. (4k was in KE38 and KE55 apparently, but no other??)
JPN-market chassis:
KE-31 — Sedan, 2-door/4-door
KE-36 — wagon, 3-door
KE-38 — Wagon, 5-door
KE-37 — Hardtop coupe (Levin)
KE-51 — Sport coupe (Levin)
KE-55 — Liftback and sedan, 4-door
NOTE:
1. KE70 models were not added as i could only find USA specs.
2. This info was sourcd using www.google.com :D and wikipedia. i simply thought it might be nice to share :D :D
3. I have a feeling that a few of my fotos may not correspond with the actual names i have given to them, so please don't flame me, rather just suggest to me what i should fix :D
KE20
KE25
KE26 (P/van has steel plates instead of rear windows, on sides)
KE27
Edited by Old-Skool-Rolla
  • Replies 49
Couple of things....
Great that a newbie is adding things and doing research instead of sponging straight away :lock:
Change the ke21 to a ke20. As far as i know there isnt a ke21 in existance.
The blue ke25 you pictured is a ke20 but the others are right.
The ke26 also came in a pannelvan.
And there is no such thing as a ke27 as far as i know. There is the genuine Te27 and thers the Ke25. A 'Ke27' is a ke25 dressed up to look like a te27.
Correct me if in wrong on anything but yeah. I'm only right into my 20-series so i couldnt tell you if anything else is wrong.
aiight, cool thanks, um, on the KE27, i had to type in TE27 to find a pic, so yeah, that would be right
With the KE21, i had never heard of a 21, only a 20, but what info i found, said only 21, so i figured they were the same, but labeled the pic, so itmatched the info, in order to avois, "well one says this, the other says that??"
and with the blue KE20/25, the same picture came up when i typed in both KE20 and KE25 so i just put it as a 25.
KE26, no excuse for this one, the info i used didnt tell me, so i didnt know :D but wouldnt the p/van, just be the same, but blacked out windows on the back??
thanks for the help mate, ill change them now for you :D :D
Nathan
first letter is the motor
second letter and number is the series shape
ke 20 uses a k-motor
te 27 uses a t-motor
So my car will technically be an "ae20" using an a-motor
Edited by JC807
but more info one KE38 Wagon (ALSO CAME OUT WIHT 4K-C MOTOR :D )
Standard Specifications:
Make TOYOTA
Family COROLLA
Model Variant SE
Car Series KE38
Year 1981
Doors and Body Style 4D WAGON
Engine Size 1.3litres (1290 cc)
Fuel System CARB
Cylinders 4
Driven Wheels RWD
Std Transmission 4M
Optional Transmission
Standard Features
Optional Features (Features offered when new and not necessarily on this car.)
Dealer Options
No Cost Options
Bore and Stroke 75x73mm
Power 45KW
Torque 94Nm
Weight to Power Ratio 20.00 : 1kg/kW
Front Brakes DC
Rear Brakes DR
Wheel Dimension 4.5Jx13
Turning Circle 9.4m
Compression Ratio 9.0
Final Ratio 4.111
Tank Capacity 47litres
Exterior Length 4050mm
Exterior Width 1570mm
Exterior Height 1390mm
Front Track 1295mm
Rear Track 1285mm
Wheel Base 2370mm
Front Suspension
Rear Suspension
Kerb Weight 900kg
Ground Clearance 170mm
Seating Capacity 5
Highway Fuel Consumption 0 (lt/100km)
City Fuel Consumption 0 (lt/100km)
Towing Capacity 0kg
Release Date 01/11/1978
Discontinued Date 01/09/1981
New Price (standard) 6922
Average Kms 0
Model Run Feb: Toy.Susp.Tuning. Disc-d Sep
VIN Location
Country of Origin
Source: www.drive.com.au therefore things are most likely wrong :D
again, but KE70 :D
Make TOYOTA
Family COROLLA
Model Variant XX
Car Series KE70
Year 1982
Doors and Body Style 4D SEDAN
Fuel System CARB
Cylinders 4
Driven Wheels RWD
Std Transmission 5M
Standard Features Alloy Wheels, Radio Cassette
Dealer Options
No Cost Options
Power 49KW
Torque 100Nm
Weight to Power Ratio 18.57 : 1kg/kW
Front Brakes DC
Rear Brakes DR
Wheel Dimension Jx13
Turning Circle 9.4m
Final Ratio 4.111
Tank Capacity 50litres
Exterior Length 4185mm
Exterior Width 1610mm
Exterior Height 1395mm
Front Track 1320mm
Rear Track 1335mm
Wheel Base 2400mm
Front Suspension
Rear Suspension
Kerb Weight 910kg
Seating Capacity 4, not infact 5 like origianlly said :D
Highway Fuel Consumption 5.6 (lt/100km)
City Fuel Consumption 7.6 (lt/100km)
Towing Capacity 750kg
Release Date 01/10/1981
Discontinued Date 01/12/1983
New Price (standard) 8055
Average Kms 0
Model Run
VIN Location
Country of Origin
