did any1 c the ke10 in the trading post this week 4sale with the 100kw 4age roll cage n all that shit..
looked pretty nice.
it goes allrite my dad built the engine and put it in duno who has the car now
a fella on the north west coast, hes pretty fast in it, was using it for hillclimbs and clubdays, but hes bought a new toy now, dare i say it........ better than the ke10 ;)
this car is very very cheap though for what it is and how its set up, could go faster though with better brakes
there is a KE35 or KE55 Coupe forsale in perth it is bright green and lowish with hotwires? can't miss it if you drive into perth from launceseton.
Hay fellas I'm selling my ke70 daily has around 2 months rego, the engine has seen better days and alt is stuffed but comes with a spare complete engine and 4 speed, average body work but the only rust in it is in the rear wheel archs n thats not major. Sprinter front bar. I'm after $400 if its taken this week.
http://www.rollaclub.com/board/index.php?s...t=0#entry176226
Cheers!!!!
Edited by 3t gte rolla on the way!!!!
Up for sale i have my KE11, i am selling it because i now live in north Queensland and can't do anything with it. It has a 4 speed box and a siezed 4K. I have the front guards and bonnet of it at the moment but everthing is there. It's currently located in Geeveston.
If anyone is interested you can e-mail me at [email protected] and I will get in contact with you.
I also have a KE36 windowless panelvan in average condition. It has a gearbox but no engine.
ADM 1983 AE86 sprinter gold in colour, 222, xxx Km on chassis, 5000km on the new build.
Small amount of rust on the bottom of the inner skin of the doors, bonnet has faded also, I have the paint and clear coat for it to be resprayed in factory colour.
Engine and Accessories:
Microtech LT10s with external ignitor module
Ae92 4agze Bottom End. (later high comp, oil squirters)
* Big port Head
* Head rebuild, new valve stem seals, valve seats replaced, cams cleaned, shimmed up
* Major porting to valve throats, eliminating a big step in the casting. Also Dedagged.
* 440cc 7mgte Injectors
* Big port rwd intake manifold and t/b
* TVIS removed
* New Rear main seal
* New Front main seal
* New oil pump gasket
* New rear main case gasket
* Genuine Head gasket
* New oil pickup gasket
* New cam seals
* New injector seals
* New T/b gasket
* New intake gasket
* New water pump gasket
* New water pump o-ring
* New rear water outlet gasket
* New RWD water pump front housing
* Flat type rear water outlet.
* FWD 4age alternator and brackets
* TPS
* Air Temp sensor
* GE water temp sensor
* GZE CAS
* GZE Coils
* Oil Pressure sender
* Water temp sensor
* Cold start injector
* Injector plugs
* Cam covers, cam pulleys, intake, t/b all powder coated a silvery colour
* Crank Pulley Machined down to 1 belt width
* Sump return for turbo
* Genuine oil Filter
* RWD 4age Mounts and brackets.
* TRD oil filler cap
Custom heat wrapped steam pipe manifold
MY00 WRX TD04 turbo, Teflon lined braided Stainless steel oil line
Go Fast Bits Atomic bleed valve
Mandrel bend Intercooler piping 2†to intercooler to 2.5†dia. matched to turbo and T/B
Silicon joins and reducers with quality heavy duty stainless hose clamps.
Alloy Front mounted intercooler
Flying plumb back blow off valve
Cold air box with K&N filter
Custom dump pipe 3" mild steel mandrel bend split system internal screamer pipe
Custom 3†exhaust mild steel mandrel bend system hi flow 3†muffle stainless 3†tip
Alloy oil catch can
Bosch 910 fuel pump
2 litre alloy surge tank
Facet hi volume low pressure lift pump
Deka dry cell battery relocated to boot
Drivetrain:
Dellows custom 4a-W5x belhousing
Supra 5 speed W58 gearbox
NEW Exedy solid ceramic sprung centre 4 button clutch upgraded pressure plate
RA23 T series diff
TRD 2way LSD
NEW Castrol syntrax full synthetic diff oil
Suspension:
New tie rods
New steering rack ends
5mm steering rack spacers
Front strut brace
Rear seat brace
AJPS 8kg front springs and short stroke KYB shocks
AJPS 6kg rear springs and short stroke KYB shocks
Noltec strut tops camber and castor adjustable
Extra adjustment castor rods
White line front sway bar 24mm 4 way adjustable
White line rear sway bar 18mm 4 way adjustable
White line adjustable panhard rod
Wheels & Tyres:
Performance Superlites 15x8 -4 offset charcoal centres
New tyres to be announced 195/50/15
Federal RS 195/50/15 Semi Comp spare tyres suit front.
Interior:
Full interior in excellent condition
Uncracked dash with dash mat
Speco boost gauge
Swede 330mm 90mm dish steering wheel
Extended boss kit
Daytona fixed back race seat currently fitted on fixed rail
Sass 4 point harness
Greddy shift knob white nylon ball type
Pioneer Head unit CD/tuner 4x50watts
Jaycar 4†splits
Spares:
Standard front bumper
Bumper indicators
Standard steering wheel
Factory sprinter alloys
Factory Nissan TRX alloys 15" mat black
Other assorted parts I have laying around.
I'm sure I have forgotten some things I will up date this when I remember.
Price $13,000 ono.
Great car for someone looking to get out on the track be it drift or grip driving.
I have a dyno sheet from the inital run in tune making 125kw at the wheels.
Its estimated the car would be now making over 130kw atw.
The car is located in Hobart Tasmania, I'm not looking to part it out at all, there will be no test drives or joy rides although I'm happy to take serious persons for a quick trip to the shops.
As you enter perth from launceston there is a white Ke30 sedan for sale! They are asking $750
do u know anymore about it? is it manual?
I'm looking for a daily.
cheers
so seriosly I'm lookoing for a daily, ke30/ke55/ta22/ra23/40/60/st141/rt142/te72 yo wateva something along those lines...
rather something under 1k
sing out if u see anything
cheers
Edited by Brendo
