Hey guys,
Just wanting to pick your brains cause my little rolla has another issue.
Okay, i've had this since the beginning and tonight it really got to me.
What happens is when she's cold and i go to accelorate, she has no grunt and doesn't wanna progress much. Usually is ok when warmed up. But tonight she didn't wanna give me much all the way home from my sisters (about 15-20km). When i wanted to go i had to rev the f@$k out of her. Like when i'd start moving she wouldn't go much and from there i had to rev her a couple times to get her moving.
Even after she was warmed up it continued.
Anyone had this problem before or knows how to fix it.
mine does that when its cold the remedy for that is wait till it warms up :lock_folder: , but it doin it when its warm i have no idea maybe a little bit of shit in your tank :lock:
Tune-up
timing
mixtures
clean carby
check:
plugs
leads
points
coil
dizzy cap and rotor button
check compression (dry and wet)
check fuel pressure and flow and carby float level.
and check your air filters not clogged and restricted
does your clutch get much slip?, can you smell it burning when you take-off?
very unlikely but check brakes for drag, shouldn't have much effect on performance unless excessive
its probably one of the things mentioned above, check in order of whats easiest and cheap to whats expensive.
Cheers, Rob
Its not doing something stupid and icing up the carby. My ke35 used to do this all the time when the twins were fitted. End up having to hold it flat in 3rd to stop it missing. Fixed it by running an air pickup close to the extractors.
Col, He lives in QLD, not Maryborough. We don't do ice. :lock_folder:
If it gets real bad, come and see me. I'm in Aspley, and I'll take a look at it.
R
Edited by Redwarf
