  • Replies 1.5k
get a ae71 there 4 door
RWD
cheap to mod for drifting cost of the car + 4age, and stiff springs probably cost u all of 4-5k
i really don't know why there arnt more corolla's drifting hahahahah
EDIT :
steve i relly wouldent go for a thick head gasket
basicly waht happens is the gasket starts to become part of the combustion chaimber and yeah i think that meens blown head gasket i seen a low comp setup like that and it blew the head gasket inbetween cyl 2 and 3 (carnt remember what its called some fancy name) just get gze pistons :)
i think u can lower the comp by retarding the timing a bit by holding the intake valve open a little longer than usual but who knoes
ute run whhhhhhhhhhhooo hoooooooo
Edited by ae174agze
I know it's red Andrew, but I think your looking at the positive battery terminal cover. I was once fooled by a similar ploy and after much research now know that the speed increase is minimal. You need to look in the glove box, for a Slim Dusty tape if you want to be truly competitive. FM 104 helps too.
What is all that other stuff around the battery terminal? Particularly interested in the black thing.
PS: Where does the map lead too, treasure?
Edited by Sbox
ahahahahahahahhahahahahah
yeah see red battery terminal is the thing that dosnt make 10psi of boost to make the engine faster :)
ahahah yes gregor follow the map sensor don't be fooled by the crank angle sensor hes a bad guy out to steal the treasure and turn left at the ecu and theres a pot of gold
Not to be confused with a for sale add, but my brother has a 4 door Mitsubishi Lance xi auto. He killed the auto but the donk is good, shell is crap and interior so so. For anyone with a Lancer this would be great for parts. He wants the $150 he has put into it and you take it away. If anyone you knows has a manual box and the bits to convert it, it would be a good rally car.
Adam can you leave this one here and ask around, as it's not worth putting it in the Australia wide section (I have had enough of mainstream stupidity for one weekend).
yeah see red battery terminal is the thing that dosnt make 10psi of boost to make the engine faster :hmm:
I wish there was a pot of gold for you Andrew, but and this is a big but. Your project is finished, I saw the damage you did to it and I don't know what to say. I will buy the turbo engine, gearbox, ae71, and other parts for $18.79 out of the kindness of my err what's it. Oh heart, that's it.
Your fall from grace will continue though, as I believe you will probably move into Nissan territory. I predict you will buy either a Nissan Insult or perhaps a Nissan Disaster (The Nissan Inferno, being your final option).
So sad as you had so much promise as a Toyota owner, you will have to be more careful in future and not drop parts.
yeah that was my bad i forgot to undo the break lines and i was un screwing it and droped out and landed on a f@$king screw-driver
and i've always been a toyota fella and most likely will always be
You did get my note on the back windscreen, that it's so minor as to be nothing?
Edited by Sbox
yeha man cheers for that aye
i was talken to a mate and he was talking about getting a one peace drive shaft made up insted of the 2 peace one he said that hes seen one split in the center bearing peace and it f@$ked up the underside of the car
Got turbo/ecu over weekend. Was going out to Custom Fabrication for quote, Didnt get there in time due to the um rolla running out of fuel LOL. Dodgy fuel guage ftl + no warning light is the gay.
