  • Replies 1.5k
Which ke70? You bought BJ's?
I was thinking one of the HKS 1.6mm or 2mm ones. Just trying to figure out what the compression would drop to. By memory I think the 20V one is 1.6mm stock meaning I would have to go the 2mm.
But yeah not sure
Picking up the turbo/ecu tonight YAAAAAAAAAAAAAAAAAY
Edit: I believe the stock 20V HG is either 1.6mm or 1.2mm
Edited by Pure-SX
Stock 20v head gasket might be 1.6mm, but that would be a non-metal head gasket, so it'd would compress FAR more than a metal one, meaning it is a lot thinner with the head tightened down than a metal one. You'd probably find a 1.6mm metal one would do the trick.
And yes, I'm buying BJ's KE70 - just gotta get the money together.
Yeah true about the HG compressing more, You gave me a price on a 1.6mm metal HG ages ago able to dig it up?
Which KE70 you putting a 4age into then?
If anyone has or knows of stuffed T50 gearbox's lurking around and they are givers, I will take them.
The new 4k is a "High Cam", man am I gonna go......................as fast as I did before.
Edited by Sbox
man y do u need a tow vehicle??? and i think a v8 superchared audi would be more pimp can't think og n e thin else atm
bowell are releasing a new car they will be using a twin supercharged v8 toyota motor
When you die, make sure that your will stipulates you are buried in a car shaped coffin (Bet you won't be able to make your mind up as to which shape of car).
Edited by Sbox
I'm pretty sure a 1.6mm was about $150 + postage. Can't be certain and I don't think I stored the price/supplier info anywhere. Remind me another time when I'm less busy and I'll get it for you.
The KE70 is the one BJ was turning into a drift car.
It turns out that the guy that wanted the input shaft (that you're turning into a clutch alignment tool) DIDN'T want the input shaft - he wants the output shaft as his was bent when his driveshaft came apart - could I grab it off you when you've pulled the T50 apart?
I need a tow vehicle for racing. I really need a ute, but I'd really like a Toyota V8. Will probably just get a Hilux. Audi's are super pimp - especially A6's and A8's (I prefer the S6, RS6, and S8 though). If you haven't seen it yet, sometime you need to watch Ronin - it's got two AWESOME chase scenes - one using an Audi S8, a Mercedes (mmm, burnout in reverse) and some Citroens, and the other chase has a BMW M5 and a Peugeot.
I don't want to be buried. Any remaining working organs are to be used for people that need them. My remains shall be cremated and spread over Bathurst through the exhaust of a Phase III GTHO. :)
It's definitely my favourite car chase in a movie, just because you can see how they did it and how professionally it was done. Bullitt with Steve McQueen is a VERY close second - mainly because of the awesome sound track during the chase - the sound of a small block Mustang and a big block Charger. :)
I've also bought 'The French Connection' 1 & 2, so I'll be watching them sometime soon. Apparently the first movie has an excellent car chase.
The french connection is a good couple of movies also. The transport series has a few also, even though they are a little unrealistic, the car more then makes up for it :dance:
I remember seeing a movie recently was kinda crap, was about to flick over and watch something else, but a car chase started with the BMW V8 with ITB's can't remember model atm, I watched the car chase then flicked over :)
Too late, dumped. While I was doing that I also accidently threw out my AE71 tailshaft, luckily Andrew won't be using his so he has given me dibs on it.
Great, your greasy residue will probably cause a crash. Probably stop the race, why Adam? Why?
I bought the Second American Civil war and you can pick a copy up on the way home Adam.
Edited by Sbox
Shit, shit, shit, bugger, damn, shit. Oh well.
I don't want to be buried. Any remaining working organs are to be used for people that need them. My remains shall be cremated and spread over Bathurst through the exhaust of a Phase III GTHO. :dance:
Because there's such a great risk of a GTHO racing with the current V8 Supercars... :)
That's not the one with Beau Bridges in it, is it? I saw that on TV once - kinda funny, but then it ends in a really weird place. Maybe because Phil Hartman was killed during the making or something.
