Jeff in Thailand Posted December 21, 2024 Report Posted December 21, 2024 I'm looking to get rid of the stock intake and exhaust manifold on my k3 engine, what would be a good replacement for these? Thanks for any help and advice. Quote
altezzaclub Posted December 22, 2024 Report Posted December 22, 2024 Have a run through this- https://www.rollaclub.com/board/topic/42407-the-girls-ke70/ Decide which carbs you want to use and start hunting for a manifold. You'll see I used SUs, popular one is a single downdraught Weber off a small Ford, better would a single side-draught DCOE Weber, but if I was to do it again I'd use bike carbs! Extractors are pretty much just the 4-1 from Redback or similar. Make sure the heights of the manifold's ears by the bolts of both inlet and exhaust are the same, use a half-washer if needed, and buy a single-piece gasket. Quote
Jeff in Thailand Posted December 22, 2024 Author Report Posted December 22, 2024 Altezzaclub,thanks so much for the info,much appreciated!! Quote
altezzaclub Posted December 22, 2024 Report Posted December 22, 2024 Why do you need one? Car modding going on? I assume your in Thailand, how's the old Corolla scene up there? Still got parts around? Check out Tommy's here- https://www.rollaclub.com/board/topic/19886-my-ke-11/page/6/#comments Quote
Jeff in Thailand Posted December 22, 2024 Author Report Posted December 22, 2024 Just a little modding,replacing the 4 speed with a 5 and want to get a little more out of the k3. Lots of Corollas here in Thailand, and seems to be plenty of parts to. Quote
altezzaclub Posted December 23, 2024 Report Posted December 23, 2024 Ah, so cam grind, head port & skim, extractors and exhaust system, and bike carbs! I don't know if a PM would reach Tommy- "Hey guys got the manifold plate cut out and also a few spares" If he still had a spare manifold plate it would make your life easy! https://www.rollaclub.com/board/topic/19886-my-ke-11/page/7/#comments You can see that a bike carb manifold has stub pipes welded onto it, and the carbs go on with a rubber hose and a clamp. So, bike carbs or DCOE Weber... Quote
Jeff in Thailand Posted December 23, 2024 Author Report Posted December 23, 2024 Got the exhaust, can get a weber 32/36 for a good price, having a hard time finding an intake manifold here in Thailand for some reason, I would like to find a single carb intake. Looking for a reputable engine shop here for a rebuild. Quote
Jeff in Thailand Posted December 23, 2024 Author Report Posted December 23, 2024 What motorcycle carbs would you suggest? Quote
altezzaclub Posted December 23, 2024 Report Posted December 23, 2024 Whatever you can get hold of in the 750-1000cc range bikes. Suzuki GSXR are most popular, Mikuni carbs. They will be 4 carbs of 36 or 38mm throat, used to running a 1000cc at 15000rpm, so you can think about the outrageous flow. Even a smaller bike will run a 3K easily, a 600-700cc 4cyl. It was on my list, but I never got around to it, the 4AGE was a much nicer way to go. Quote
Jeff in Thailand Posted December 23, 2024 Author Report Posted December 23, 2024 I was looking at some 4age motors,not sure of what all the changes I would have to make for it to fit in . Quote
