I am a new here and just want to know what I can do to my car. I have an 88' 4a-ge ae82 rolla. it is a twin cam red top 16v 4a-ge. All that has been done to the engine is a pod filter. It also has a 6" tip for the exhaust. no performance just a mean sound. I just want to know how I can the most performance out of the car with the least price, whether I try extractors, injectors or an safc computer to tune my stock computer.
Here are some pictures.
it is a bit dirty, i take it fishing on dirt roads and tear it up a bit. through the sand sometimes also :jamie:
Edited by aedan_man
hey, extractors and a good exhaust system should be the 1st mod, talk to nickz the resident ecu man for a comp.a tip i was told by a mechanic if u mod the intake side of things u should mod the exhaust side aswell.hope i helped a bit.cheers :jamie:
Don't waste your money on an SAFC, Just spend the extra money and get an aftermarket ECU installed. Then mabey a CAS off a GZE with multiple coilpacks to upgrade the ignition side of things, Some bigger injectors, Different cams with cam gears etc.
I've got some stainless 20V fwd primaries here if your interested, $40. You just need the 2 outer bolt holes slotted to make it bolt up. Stick away from fuel only computers, control of your timing when you change the fuel mix is a very handy thing.
