Hi all,
Has anyone done this conversion and can shed some light onto the sump modifications required or sump to purchase to make this conversion happen.
Interesting-
A couple of grand ($US!) would buy one that might do it...
https://www.keconversions.com/product/3RZ-ST141-corona-sump-custom-turbo-conversion/167?cp=true&sa=false&sbp=false&q=false&category_id=27
and does it work with their KE20 conversion kit?
https://www.keconversions.com/product/3RZ-2RZ-KE30-KE55-TE31-engine-conversion-mounts-swap/35?cp=true&sa=false&sbp=false&q=false&category_id=27
If not, you need to be a very neat sheet-metal welder and make your own sump welded onto the 3RZ base. Get hold of KEConversions and ask them.
I can't get excited about the 3RZ though, its 175kg stuck in the nose for a low-power engine with lots of torque. Nothing better you could use?
