frosty Posted December 10, 2023 Report Posted December 10, 2023 Would anyone know if you could bolt up ST141 Corona brakes to the ke70/55 strut to achieve 250mm discs? thanks Quote
Banjo Posted December 10, 2023 Report Posted December 10, 2023 (edited) Hi Mate ! Lots of details on here, if you go searching; regarding brake upgrades on the front of KE30/55/70 Rollas, as Rollas were never well known, for their "great braking ability" I remember reading lots a threads, when I did my front end upgrade years ago, which was a resounding success. However, it involved replacing the whole strut, LCAs, & discs & calipers. When I finished, I found I had to replace the brake master cylinder with a Mitsi Pajero one. I finished up with Corona struts, 3T Toyo adjustable top pivots, Cresida discs & calipers off to different model Cresidas; & the Pajero master cylinder. It was quite a journey, & I learnt a lot, but the end result, has proven to be reliable & trouble free. Go back & look through my posts, & you'll find a lot of info there, along with a few pics. https://www.rollaclub.com/board/topic/63524-ke-3055-brake-upgrade/#comments Cheers Banjo Edited December 11, 2023 by Banjo 1 Quote
frosty Posted December 11, 2023 Author Report Posted December 11, 2023 cheers for the reply Banjo ~ I had had a search to no avail. I knew about replacing the whole strut, but my question was really about wether the ST141 corona brakes - backing plate, rotor and caliper ~ would actually just bolt to the existing strut. Quote
Banjo Posted December 11, 2023 Report Posted December 11, 2023 Others may correct me; but I thing the simple answer is no. It's over a decade ago now, since I did mine; but At least, I think I had to replace the top pivots, & they had to be adjustable to get the camber right. I know it was a good learning experience, & there was a lot of measurements taken, with the wheels & weight on a flat concrete floor. Steering linkage lengths also came into play. I'll have a read through my original thread tonight, & see if it brings back other memories of this exercise to light. I do remember, I also fitted a much thicker anti-sway bar, which really helped, & some really good Koni shockers in the Corona strut tubes. I seem to remember, there was a very popular conversion, called the "PUG" conversion, which used an early model Peugeot disc caliper off memory. I do remember, that you had to weld the lower spring support & retainer on, so that when the wheel was hanging free, that there was still some compression on the spring, at all times. Cheers Banjo Quote
