We all do this at some time, but here is a variation of a method, I have used for years; which creates a wire join, in your engine bay; under the dash, or in the boot; that You will never have to revisit again, & will last as long as the car.
https://youtu.be/lrIefG-bbj8
What is my variation ?   Exactly the way this guy does it, but I then solder the joint, & the "shrink tubing" I use, has a heat activated adhesive on the inside, which will not let any moisture inside the joint; which could ultimately cause corosion to any exposed metal of the wire joint.
Cheers  Banjo
Edited by Banjo
