35 minutes ago, altezzaclub said:
What you might find is someone has joined the red wire to the black/orange already, probably under the dash, and their connection has broken or is loose.
Oh I see...means for confirming broken or loose...I take one new wire from under dash red wire point to +ve coil...if can start up means confirm that wire is problem maker.
"I take one new wire from under dash red wire point to +ve coil...if can start up means confirm that wire is problem maker. "
Yes, that's it. Once you are chasing that red wire you will probably find the problem quite easily.
15 minutes ago, altezzaclub said:
So, how far have you got? Does it start nicely yet?
Sorry brother I'm still stuck on job at outstation..not back to my home yet.
After I back home and repair 1st then I let you know ok or not.
Edited by Vincent
