Hi All,
For anyone who has done a beams conversion on a KE55 using the stock intake, what brake booster/master cylinder did you use to clear?
I have tried what the wreckers told me was a Starlet EP91 booster but the overall diameter was too large and fouled on the inner guards. Would also be interested in any pics of completed conversions.
Thanks,
Matt
  • Upvote 1
If you run into idle problems when you have it running, try a different air filter setup, especially lengthening the tube before the MAF sensor.  Quite a few guys had troubles with aftermarket air filters like that, the airflow was too disturbed for the sensor. One guy filled the tube with plastic straws to reduce the turbulence.
