towe001 Posted July 7, 2006 Report Posted July 7, 2006 To answer your questions. Yes the corolla came with a diesel, it was the CE71 or whatever the number was. It was used in the last rear wheel drive model both the change to front wheel drive. I can't see anything too hard with swapping the motor into a ke3x to ke7x, just would have to do the usual things - engine and gearbox mounts, prop shaft, gearbox, etc. And brakes and suspension due to the heavier motor. But all-in-all for the little bit of fuel economy that you'd get just wouldn't be worth the time, energy and cost that you'd put into it. Quote
Trev Posted July 7, 2006 Report Posted July 7, 2006 You will also have to change the diff over to a low ratio as petrol diff's are normally high. Quote
love ke70 Posted July 8, 2006 Report Posted July 8, 2006 To answer your questions.Yes the corolla came with a diesel, it was the CE71 or whatever the number was. It was used in the last rear wheel drive model both the change to front wheel drive. I can't see anything too hard with swapping the motor into a ke3x to ke7x, just would have to do the usual things - engine and gearbox mounts, prop shaft, gearbox, etc. And brakes and suspension due to the heavier motor. But all-in-all for the little bit of fuel economy that you'd get just wouldn't be worth the time, energy and cost that you'd put into it. prove it Quote
Jono Posted July 8, 2006 Report Posted July 8, 2006 you would have to drive it for ages to make any sort of gain from the economy vs. the amount spent on doing it. ever thought of buying an old diesel merc? Quote
Teddy Posted July 8, 2006 Report Posted July 8, 2006 i really cbf cleaning this thread, i don't really want to get onto the bad side of people.. Yes there are corolla diesels out there. Yes they are slow. Yes they are good on fuel. Yes australia never got them new. all happy now :dance: Quote
towe001 Posted July 9, 2006 Report Posted July 9, 2006 prove it :hmm: Proving that the time, effort and money to prove a point would just prove to be a waste of time, effort and money in proving something pointless. :y: Quote
