  • Replies 55
I'd help more people if I had more free time and my knowledge was a bit better. Unfortunatly I'm only limited to KE70/AE71/AE86 problems that I've come across before. Lucky Ryan lives close to where I work so its easy to drop in on the way home from work..
thanks again justin,
yeah it wasnt that
I'm not sure about what you said that they both had constant 12v cause i tested it with a volt meter and didnt get a reading.
what did you think about the car otherwise?
oi man its alive!!!!!!!!
you know the yellow wire on the 10 pin plug, after i had my little eathing frenzy i connected that up to ignition switched power and it started first try :P thanks again for your help and feel free to stop in when ever you want for some beers (jim beams) or what ever, i can even take you for a drive sometime soon, all i have to do now is wait for my custom throttle cable to be made up probably tomorrow at the latest and then drive down to midas to get an exhaust made up.
then the final thing on my list is this coming fridays drift practice, moihahahahahaha
cheers
beally.
