  • Replies 37
:dance: WoW, thats trippy. The before and after pics. Everything is in the same spot the only differance is that the car is painted. The grass looks greener too, was that painted?? lOl
Edited by JiP_01
:hmm: -Hey, hot wheels!!!
Doesn't it suck how the peddels are attached to the floor??
I had to cut into my floor mat. :y:
Edited by JiP_01
The auto tail shaft will not fit in the manual gearbox, you need a manual one, you also need a different extension housing to bolt a KE70 manual into a KE55, and once you put a KE55 extension housing on the box, you will have the correct speedo drive in the gearbox to suit your KE55 dash.
Car is looking good by the way :hmm:
Ive got the gearbox bolted in with a custom crossmember.
would i be able to use either:
A: KE70 speedo cable
or
B: KE55 speedo drive
Cheers, Rob
KE70 shifter position
http://i57.photobucket.com/albums/g209/Rob..._01/shifter.jpg
Modified Crossmember
http://i57.photobucket.com/albums/g209/Rob...crossmember.jpg
KE30 Bonnet and grille, soon to be painted
http://i57.photobucket.com/albums/g209/Rob.../ke30bonnet.jpg
http://i57.photobucket.com/albums/g209/Rob.../ke30grille.jpg
My carby f@$ked itself today, and started pissing petrol out, i think its leaking through the accelerator pump, hopefully ill sort that out tomorrow.
http://i57.photobucket.com/albums/g209/Rob...nginenocarb.jpg
http://i57.photobucket.com/albums/g209/Robert3_01/carbys.jpg
