turbo_sloth Posted June 11, 2006 Report Posted June 11, 2006 I would love to put a 4age 20v in my Ae92 but i was thinking for now i might just mod my 4afe. i was thinking of cams and clutch, what would be good bang for buck? trying to stay NA. but would love to go turbo if a cheap way is good. Quote
MYSTIK[RL] Posted June 12, 2006 Report Posted June 12, 2006 i wouldnt bother modding the 4afe its one of the eco versions of the 4a motor. Instead save that money and put it toward either the conversion or making ur ae92 handle first. my 2 cents or i should say 5 cents with inflation :thumbsup: Quote
peedman Posted June 13, 2006 Report Posted June 13, 2006 Why not go 16V conversion and going from there. Its cheaper than a 20v but you got more options than using your 4afe. Quote
Felix Posted June 13, 2006 Report Posted June 13, 2006 a 4afe already is a 16v. :thumbsup: i don't think it would be that hard to make 20v sort of power (whilst still being reliable), with a well thoughtout mild boost turbo conversion. Quote
turbo_sloth Posted June 13, 2006 Author Report Posted June 13, 2006 Well i was thinking of getting a custom turbo manafold made for a small turbo from a turbo ford courior or something. not aheap of boost but boost still. and maybe it would last till i have money for my 20v swap. I want to use a silver 20v coz they look really good and have a good amount of power. i would prob leave the 20v standard, apart from exhaust and cold air intake, we'll have to wait and see. I might get a bit power hungry. Quote
Felix Posted June 13, 2006 Report Posted June 13, 2006 i was reading on some american forum that the 4afe's will run happily up to 10psi, with an intercooler and good tune. the pistons go bang at 15psi. if you want more it is either internal work or conversion time. Quote
turbo_sloth Posted June 14, 2006 Author Report Posted June 14, 2006 Hmm...that sounds good. i would love to run about 10 psi with cooler. it would be a nice bit of power gain. would i have to get anything done to the computer? can the standard ecu be modded? Quote
Hiro Protagonist Posted June 14, 2006 Report Posted June 14, 2006 Unless you know someone with a spare silvertop head running around, it might just be easier (and cheaper in the long run) just getting a silvertop front cut and putting the whole 4AGE 20v in, plus gearbox, and selling everything that you don't need. Quote
turbo_sloth Posted June 14, 2006 Author Report Posted June 14, 2006 yeah i was going to get a half cut from a jap importer. i have a fair bit of mechanical skils and know how. i think i'd do most if the work myself and see if i could do it all myself. and any questions i have i'm sure i could get answered on a forum. :thumbsup: Quote
Felix Posted June 15, 2006 Report Posted June 15, 2006 have a search around on the HMT forums. quite a bit of info about 4afe's and ecu workarounds. Quote
flamingheads Posted December 8, 2006 Report Posted December 8, 2006 (edited) I know this is an old thread but I got an AE95 4wd rolla with a 4AFE and was wondering about simple engine mods. I was just thinking of an air filter and sticking on a muffler I've already got. Would this do anything or would it just be cosmetic? Any suggestions other than engine swaps and turbos? I'm seriously broke right now. Oh and first post. Edited December 8, 2006 by flamingheads Quote
Lordnafe Posted December 15, 2006 Report Posted December 15, 2006 simplest way to gain power out of a 4afe is to remove head, get 4age head, get .8mm trd hadgasket, bolt 4age head onto 4afe bottom end and away you go :) won't make as much power as a factory 4age due to lower compression, but won't go bad. obviously will need 4age injectors and ecu too. Quote
JedzWagn Posted February 17, 2011 Report Posted February 17, 2011 4age head won't bolt onto 4afe block Quote
Trev Posted February 17, 2011 Report Posted February 17, 2011 4age head won't bolt onto 4afe block How sure are you, care to elaborate? Quote
MYSTIK[RL] Posted February 17, 2011 Report Posted February 17, 2011 4age head won't bolt onto 4afe block :blinks: :blinks: How sure are you, care to elaborate? +1 *goes and makes popcorn in anticipation of the answer* Quote
