bit hard considering theres no drag strip ( :P ) in Adelaide
What time would i have to beat though? out of interest :D
Not asking you to beat anytime , you blokes were the ones comparing dick sizes.
I know how big mine is just don't go showing it around.
  • Replies 34
I wasnt joking, I'm fairly new to the forum and have read a LITTLE about your car but don't know how quick it is down the 1/4 mile.
If we go off 1/4 times ill have a small dick anyway, lol
Cos I'm only running 175 rear tyres=no grip in the first 3-4 gears
I'm not into bragging about my Et's
I ran the car once on 16Psi due to the clutch not holding anymore boost, it ran 13.7@103MPh which is the limit at 6800rpm, std gearing with 205/70/13's
For anyone that wants to work it out ,it is around 165RwHp with a weight of 880Kg i think we worked it out at.
The reason i put that in is some people RECKON they know that my engine cannot make that much power with that turbo,injectors RA,RA,RA.
The engine has made to date 149RwKw, so if i can get it to the ground and grab some more gearing it should run some very good numbers.
Nice work, I'm using a S5 RX7 g/box so gearing wont be a problem for me (5spd). Running the standard turbo, front mount and just a few other basic mods. Looking at around the 160-170 rwkw which is definitely enough in a small/light car. But as you have said traction is a major issue
  • 2 months later...
I'd give you's all a run, but my feet are sore and I'm tired
"I will just activate my cars wings and fly away" To quote one of my all time favourite movies
"How wants a mustache ride? " :D
