been pulling my 4k from my ke70 apart, as was planning to rebuild with tough cam
but
I'm really getting the shits with looking at the stupid lil 1.3 and thinkin its not worth it
so i been thinkin new engine but i wanna keep it simple so i can do most of the work
so i been thinkin
4age twincam 16v
or being a cheap ass with a 5k
probably the 5k
cause i got the k 50 gearbox, which probably wouldnt last to long with a 4age
i want to get a t18 diff and swap across a trd 2 way lsd center
any ideas or comments people?
You'd need a T50 gearbox to bolt up to a 4AGE anyway, unless you went out and got a bellhousing that will adapt a W5x series gearbox from a Supra.
Go the 5k and get that going hard with a set of side-draft weber carbs.
That way you don't have the hassle of wiring up an engine and adding a lift pump and surge tank etc etc to your current fuel system to get EFI to work on the car.
How much did you want to spend?
If you ain't got much to spend, then go the cheap 5K fix.
Otherwise, if you have the funds... do the 4AGE swap.
but whats right with it?
its old, slow, poopy, pushrod goodness that produces bugger all power for the fuel it uses.
paint them blue i say, BLUE!!!
You've stolen my line.
K motors have their place, and contrary to your belief, not at the bottom of the ocean.
Pity you never got to see Evo 1 with it's k motor.
man i got the cash its just that...you guys are going to hate me but
its only a corolla
i really don't think that its really worth spending over two G on my one
k power sounds the go
il save my G's on a SC400 / crown v8
Edited by OniBerserker
quit it, k motors are bulletproof, simple to work on and extremely cheap
um... you get what you pay for... its pretty obvious k motors aren't going to match engines that cost like 10 times the price
...and they don't go THAT badly
Edited by rjenman
