chrisandliz[RL] Posted May 21, 2006 Report Posted May 21, 2006 hi boyz, just got a ke 20 auto (beggers can't be choosers) and want to change the box over to a manual, is it hard to fit a cluch pedel and is the drive line overly diffrent?? :) Quote
Redwarf Posted May 21, 2006 Report Posted May 21, 2006 Felix is in the process of doing this very conversion..... Quote
chrisandliz[RL] Posted May 21, 2006 Author Report Posted May 21, 2006 Auto to Manual Pedalbox changes are the spawn of satan Nick adds his 2 cents by saying "If you want a manual car, its easier to just go and buy one that is already manual" heh tell you want, if i see one ill buy it :) Quote
Taz_Rx Posted May 22, 2006 Report Posted May 22, 2006 PM tas_corolla, I just sold him an auto box to do a manual to auto conversion, so he'll have a clutch pedal for sale probably. :) Quote
chrisandliz[RL] Posted May 22, 2006 Author Report Posted May 22, 2006 PM tas_corolla, I just sold him an auto box to do a manual to auto conversion, so he'll have a clutch pedal for sale probably. :) i guess tas-corolla, is in tasie, i'm in wa. thats a little far to walk :) Quote
Taz_Rx Posted May 22, 2006 Report Posted May 22, 2006 would probably cost all of $10 through aus-post. was just letting you know that he had 1 available. :) Quote
Corolla_Kid Posted May 22, 2006 Report Posted May 22, 2006 Pretty easy in a ke20 if i remember correctly. Just need the ke20 manual pedal box and it bolts in relativley easy. It was a while ago but i think it only took a couple of hours. Quote
coln72 Posted May 22, 2006 Report Posted May 22, 2006 Thinking the same thing medicine man. Sure it only took the old man a lazy weekend to do his KE30. Easy if you have acess to a manual car to swap the bits straight over :) Quote
Taz_Rx Posted May 22, 2006 Report Posted May 22, 2006 thats what i was on about, tas_corolla is doing manual to auto and your doing auto to maunal, both in ke20's, get in contact with him. Quote
chrisandliz[RL] Posted May 22, 2006 Author Report Posted May 22, 2006 sorry, now i'm on the right page, thanks boys, oh do i need a new crossmember? Quote
Corolla_Kid Posted May 22, 2006 Report Posted May 22, 2006 If i remember correctly i just used the same cross member. Quote
Redwarf Posted May 22, 2006 Report Posted May 22, 2006 (edited) Having mot half an hour ago finished pulling a pedal box out of a 20 I can tell you a number of things. It took me about 30 minutes (using air tools) to remove. Three bolts holding steering column, three nuts holding on wiper motor (pray to god you never have to change one of these) and the bolts holding the forward end to the bulkhead, for this car it was five nuts/ bolts, your's will probably have three or four, as this one had been modded. Disconnect the brake light switch, the clutch cable and brake MC pushrod, then reef, pull, twist and generally root around until it comes out. I also removed the attach bracket that goes between the steering column, and the PB. You may also want to remove the dash for better access to the top bolts, add 5 to 20 minutes for this depending on who's been at the car before you. Installation is the reverse, and will realistically take about twice as long as removal. *Disclaimer: These times are a rough guide. I used a rattle gun and an air ratchet on everything, have access to good tooling, and I know my way around a twenty fairly well. * Hope this helps. R Edited May 22, 2006 by Redwarf Quote
Jason Posted May 22, 2006 Report Posted May 22, 2006 bah stop ya bitching i took me a day to install the dash and pedals steering colum and other stuff :) Quote
Redwarf Posted May 22, 2006 Report Posted May 22, 2006 Thats a 70, there'd been over 10 years of technology by then. :) Quote
Felix Posted May 22, 2006 Report Posted May 22, 2006 i did an auto to manual conversion on a mates ke30 at one stage. from what i remember (was a while ago) it wasn't that difficult. we did it in a laid back manner over 2 days. the pedal box wasn't an issue from memory. i have pulled a manual pedal box out of a ke10, it was pretty easy. haven't touched a ke2x one yet.... you are scaring me Rob. :) Quote
