Hey guys, i bought some work equip reps for my 82 and on inspection without the tire fitted it looks like they'll rub without spacers. Can someone recommend any hub centric spacers? I know i could get some on ebay but id rather ask here first before turning to something cheap from ebay.
Also thinking about getting coilovers  and am set on BC's. Thoughts??
For the meantime i was thinking of just getting some camber plates for the stock struts.. Has anyone done this and is it "worth it"?
Is it worth it?  It depends on what you plan on using the car for.  If it’s a street car I would say no it isn’t.  You will probably turn it into a poor handling pig that you hate.
if you plan on it being a competition car and spend some time sorting it properly, maybe.
Assuming it’s a daily driver street car, leave the strut tops alone and put some uprated, lowered variable rate springs and improved dampers in it and it will be great
