Tham Posted May 12, 2006 Report Posted May 12, 2006 (edited) I have just bought a Nippondenso electronic distributor from one of the salvage yards, with a built-in ignitor. The vacuum advance diaphragm on this unit is a two-stage type, with two ports, one on top of the other. The one on the stock points distributor of course has just one port for direct connection to the carburetor's vacuum inlet. The salvage yard owner gave me a T-joint to connect the single hose from the carb to both ports of this new vacuum advance. Alternatively, he told me that those plastic/metal splitters for hoses of aquarium air pumps could be used. I wonder if this is the correct method ? My usual mechanic, as well as a car wireman, told me that only the lower port should be used and the upper one left unused. It also comes with what I think is a vacuum delay valve, very similar to that show in this pic : http://www.top-downsolutions.com/images/309050.jpg Which port should this go to, and which side faces the which ? Or can this be left out ? Thanks to the very informative users in this great forum. Edited May 13, 2006 by Tham Quote
Medicine_Man Posted May 13, 2006 Report Posted May 13, 2006 It's Probably something like this http://www.rollaclub.com/faq/images/3/35/VTV.jpg more info on the faq.. http://www.rollaclub.com/faq/index.php?tit...stem_Components Quote
Medicine_Man Posted May 13, 2006 Report Posted May 13, 2006 It also comes with what I think is a vacuum delay valve,very similar to that show in this pic : http://www.top-downsolutions.com/images/309050.jpg Which port should this go to, and which side faces the which ? Or can this be left out ? Thanks to the very informative uses in this great forum. Suck and blow on it, You will soon find out which way the vacuum goes.. Quote
mikeys toy[RL] Posted May 14, 2006 Report Posted May 14, 2006 the one fathest out is the advance, the inner one goes to the manifold for the retard Quote
Tham Posted May 14, 2006 Author Report Posted May 14, 2006 Thank you, Medicine Man and Mikey's Toy. The vacuum diaphragm on my electronic distributor looks very much like this : http://www.japparts.com.au/products/distri...%20Dis.%201.JPG Quote
Tham Posted May 14, 2006 Author Report Posted May 14, 2006 (edited) The one farthest out is the advance, the inner one goes to the manifold for the retard Does that mean I should connect the hose only to the outer one and leave the inner one unused ? Edited May 14, 2006 by Tham Quote
coln72 Posted May 14, 2006 Report Posted May 14, 2006 Had one of those and used both ports as when we tested it, it gave the most advance on my engine. Quote
rsdn Posted May 20, 2006 Report Posted May 20, 2006 hi tham.. how have u been.... may i know where did ya get the Nippondenso electronic distributor?? How much did it cost?? thanks man.... Quote
Tham Posted May 20, 2006 Author Report Posted May 20, 2006 From Soon Choi, Cheras, as mentioned in my earlier posts. Cost $180. Quote
rsdn Posted May 20, 2006 Report Posted May 20, 2006 Hi again.... U mention that is was internally ignited.... Does that mean we dun need the coil.... Quote
woteva Posted May 21, 2006 Report Posted May 21, 2006 Internal ignitor type: http://i5.photobucket.com/albums/y167/aaro...stributorin.jpg http://i5.photobucket.com/albums/y167/aaro...tributorout.jpg http://i5.photobucket.com/albums/y167/aaro...tributortag.jpg A. Quote
Tham Posted May 21, 2006 Author Report Posted May 21, 2006 http://i5.photobucket.com/albums/y167/aaro...tributortag.jpg Nice photographs. The one I purchased looked very similar, even the two-stage vacuum diaphragm. Mine had serial number 19050-13130. Quote
woteva Posted May 21, 2006 Report Posted May 21, 2006 Nice photographs. Thank you. I bought mine from U-Pull-It, in South Australia for $28.50. It had a cap on it so the bloke didn't realise it was electronic, I guess. Bargain!! It had a 2 stage vacuum advance too, with a T connector, so I just dropped it in and it worked. A. Quote
Tham Posted May 22, 2006 Author Report Posted May 22, 2006 Wow. That is a real bargain. Just M$75 here, less than half of what I paid for it. The salvage yard owner threw in an old electronic coil made by Hanshin of Japan though. I'm still using my old points coil with a resistor, as the above coil looks really old. Wonder if the performance will be better with the electronic coil. It had a 2 stage vacuum advance too, witha T connector, so I just dropped it in and it worked. Did you connect the T-connector direct to both ports ? Did it come with a vacuum delay advance like the one shown in my link above, and if so, how did you connect it ? Thanks. Quote
woteva Posted May 22, 2006 Report Posted May 22, 2006 Did you connect the T-connector direct to both ports ? Did it come with a vacuum delay advance like the one shown in my link above, and if so, how did you connect it ? Thanks. It didn't come with a delay advance, but I removed it from a 4k engine so it could have been installed by anyone, yes the T connector just splits the vacuum from the manifold to both ports on the advance, and I just connected the wires to my existing coil and ballast resistor setup. As I said this is the way I found it set up on the 4K in the yard and I put it on mine the same, but it is not neccessarily the correct way? Good luck. A. Quote
