Hello:) I'm currently building a ke25 with a 2tg turbo engine.
I will use a t293 Axle from a te71gt.  But This is wider then the ke25 Axle. So My question is, Do i have to run flares or will i be able to tuck some wheels under the fender?
Question 2: Does anyone know if air shocks are available for This car?
quation 3:  Does a ke20 fuel tank fit the  ke25?:)
You either need to fit flares after major surgery on the rear guards, or get the diff narrowed.
Fuel tanks are the same
