Rolln666KE20 Posted July 16, 2018 Report Posted July 16, 2018 Anyone help me out for this little girl, 4 speed just doesn't cut it haha Quote
Banjo Posted July 17, 2018 Report Posted July 17, 2018 (edited) That is just the sweetest looking Rolla ! Which 5 speed are you after ? The KE55 5 speed will drop in without issues, as dimenensionally it is the same as the 4 speed. The other 5 speed available is the 5 speed gearbox from a KE70,, which has the same overall dimensions, but has the point where the gear-stick comes out, a little further back. This will require cutting out your tunnel a bit, & filling the hole at the front. If you don't want to molest the floor pan/tunnel, then the KE55, 5 speed is the one to go for. Cheers Banjo Edited July 17, 2018 by Banjo Quote
