It appears there were quite a few different types of dizzy for the 3Y, with both points & electronic.
http://brianlawson59.blogspot.com.au/2012/03/distributors.html
The ones for South Africa, were apparently different, & that is where Sipho is located.
As Sipho has replaced the condensor, we have to assume it is a points type, which were fitted mainly to the 3Y engines, according to this blog at the above link.
Maybe Sipho, your issue is with the rotor or the spring & carbon rubbing point in the top of the dizzy cap.
Would need a bit more info, to solve this one. At least if it is points, it is the cheapest & easiest to fix.
Cheers Banjo
