thefallen1 Posted December 11, 2017 Report Posted December 11, 2017 Hey everyone, Just a question has anyone put a new clutch in their KE10? I'm looking at one on eBay and I'm seeing if anyone has used it before and if its any good. If not does anyone has any good recommendations? Quote
Taz_Rx Posted December 11, 2017 Report Posted December 11, 2017 I bolted one on my 55 today. Will let you know what it's like in due course. Quote
altezzaclub Posted December 11, 2017 Report Posted December 11, 2017 I replaced the 4K clutch a few years back & one day it developed a bad shudder. Pulling it out showed that one of the thin spring-steel fingers had broken and moved sideways to sit jammed up on the next finger by the next rivet. This gave a bulge in the plate. So I went to Brake & Clutch locally & they sold me an Exedy kit, the only type available. It ran for a month or two and then slipped! I rigged a weight system on a drill press to see how many Kg it took to push in the pressure plate & found the new one only had 2/3 the pressure of the old. Brake & Clutch were not interested, and I fitted the old pressure plate to the new clutch plate... Still going strong... So some new stuff is not all that good, don't throw out the old clutch. Quote
thefallen1 Posted December 11, 2017 Author Report Posted December 11, 2017 far out, do they not make anything for these car good anymore. All you read about is dead part numbers and shitty repro parts. so frustrating Thanks for the quick answers gentlemen, hopefully this will help someone as well when the run into the same issues and jump on this site searching for answers. Quote
