Hey all,
Figured I'd throw up a build thread for this with the hopes it'll keep me motivated and on track (lol)
Bought this back in Jul'15 and drove it back home from QLD. I'll be honest, it was a pretty scary drive! The suspension was set up for track use with oversized sway bars, strut & piller supports and the dampers set to the hardest setting. Thing was skittish a.f on the rural QLD roads, even at lower speeds, and I found myself bounced into the opposing lane several times and once into the path of a truck. Needless to say that, in conjunction with the miserable weather and poor visibility at the time, I found myself holding the wheel with a death grip and frayed nerves! Then I hit a bloody wombat! The fat little bastard tore out the rear sway bay on his way though, thankfully not damaging the mounts, and I found myself with the swaybar digging into the pavement. However, with a little bit of bush ingenuity and the handy help of the edge of the bitumen, I managed to bend it back up outta the way until I could remove it at the next service station. Funnily enough, removing the bar actually did wonders for the stability of the car and my peace of mind with the remaining 30hr drive being much less stressful!
I'll Split this into 2 parts, how I got it and my plans ahead..
So here's a snapshot from when I picked it up:
'84 ADM AE86
BODY
- Letterbox Levin Front End
- Carbon Fibre Bonnet
- Front bar modified for the intercooler
- Rolled front guards
- Screwed on +40mm Rear Over Fenders
- Beatrush Undertray
- Beatrush Rad Cover
DRIVETRAIN
- 4AGTE
- Deburred and polished 4AGZE Block
- ARP Main Studs & Head Bolts
- ARP Rod Bolts
- Cometic Head Gasket
- Motec ECU
- High Mount Turbo
- Front Mount Intercooler
- Oil Filter Relocation Kit
- Dual Coilpacks
- T50 gearbox
- T-Series disk 1.5way Kaaz LSD
- Running ~18psi Boost
SUSPENSION
- Shockworks Coilovers
- Front Strut Brace
- Front Fender Brace
- Rear Strut Brace
- TTT Oversized Rear Swaybar
- TTT Oversized Front Swaybar
- Adjustable Panhard Rod
- Modified cross member to include camber adjustment
- Upgraded steering components and urethane bushes
- TTT Adjustable tie rods
- TTT Steering Knuckle
- TTT Tension Control Rods
BRAKES
- Disk rear end
- braided front brake lines
- Wilwood oversized calipers
- Drilled and slotted rotors
INTERIOR
- Recaro Bucket Seat
- Complete Plastics (Brown)
- Battery Relocated to Boot
- Standard cracked dash  with mat
- Electronic Gauges
WHEELS
- Rota 15x8 0 Front
- Rota 15x9 -20 Rear
- Spare pair Rota 15x9 -10
Here's some pictures from the previous owner:
1172890_10201048536029760_1976897050_o.thumb.jpg.d991a55a38bf13e79d83d42029c5db67.jpg10469699_10203240767834185_3871108067955102838_n.jpg.df1026587b042554829eab4cb2032fa9.jpg
And this is the day I picked her up
11745777_10152873826410947_8485760828595684700_n.jpg.4b716bb63b4afa625eac7c5e59d4aa8a.jpg
As for Current/Future Plans:
BODY
- Zenki Trueno Front End
- Shaved boot lock
- Shaved antenna hole
- Blended +40mm Rear Over Fenders
DRIVETRAIN
- Tidy up the engine bay, change out and re-path some of the hoses/ Wiring
- W55 Gearbox & short Shifter
- Soft Button Clutch to suit
SUSPENSION
- Standard Rear Swaybar
- Standard Front Swaybar
- Replace Cross Member, Steering rack and Steering column with components for power steering conversion.
- Replace any worn bushes/ components as needed
INTERIOR
- New Carpet
- Replace the Dash
- Rewire and Re position Electronic Gauges
Will Upload some current pics in the near future, stay tuned!
Edited by Burcoty
  • Upvote 1
On 8/11/2017 at 9:47 AM, ausca62 said:
Looks awsum mate. Great to see it out there having a crack, not just a show piece. Love it.
Cheers!
Yeah I like driving too much to make something like a show piece lol
I have property and family out your way so with any luck we'll probably bump into each other at one of the events held over there once I've got her sorted an back on the road!
Hey that's a nice car.  Swaybars are the worst thing you can add to an E chassis rwd car, unless you want to understeer, then snap oversteer and crash.  That wombat did you a big favour and even got involved tuning your car.  Wombats rule.
Small Update
Here's how the car sits at the moment.
As you can see it has most of the trueno front end fitted, the rear fenders have also already been blended and repainted to match.
I also picked up some Climair visors which I'm fairly happy with.
Have also removed all the turbo setup, and started tackling the interior.
Engine will be coming out in the next week or so so that I can install the power steering crossmember, rack and column.
I'll also be reinstalling all the heater/fan stuff so that I can pass roadworthy and see out the windscreen plus not freeze my butt off during winter!
On top of that I hope to be able to re-rout some of the wiring to neaten it up, depending on how much of a PITA it's gonna be..
Anyways, most of my time in recent days has been spent cleaning, sorting and paneling the walls in my shed so that I can actually use it again!
Have way too much stuff >_< Thankfully have been able to pick up some industrial shelving so that should help with the organization and then, once I have it usable again, I'll get more stuck into the car.. hopefully
Stay Tuned
Edited by Burcoty
Another small update:
Have stripped out the dash, centre console and disconnected gauges etc. in preparation to tackle wiring, reinstall heating and swap out steering column! Just need to locate my soldering iron, solder and wire then stock up on heat wrap an I'll be ready to go.
Also almost finished organizing my shed so that it's usable and not ridiculously cluttered, only a bit left to go and I'll be satisfied enough to get stuck into the car properly ^_^
Don't have any pics from before I started but you can see some of the progress from the pictures In my last post.
Having storage really helps!
Anyways, until next time!
Edited by Burcoty
So today I got around to doing some more work to the car, haven't worked with turbo engines much before so hoping I remember where everything goes lol
Anyways, spent the morning removing the engine and front end, still have to pull out the steering column but ran out of time.
Looks like there's a few oil leaks and some interesting piping which will get cleaned up while I'm at it.
That's pretty much it for now, 'till next time.
Edited by Burcoty
That car looks familiar....I assume it was making the rounds on ae86dc back in the day. that red color seems different than the normal 86 red?
Looks like you are getting stuck into the project.
I'm not sure, I think it was advertised there but beyond that I don't know, at least I'm not aware of any build threads or the sort *shrugs*
Yeah, been doing what I can, when I can, around Uni, work an family.
Another small update tho:
Engine is completely seperated now, sitting on a trolley for easy maneuverability. Have started stripping off the parts that I'll be replacing/changing.
And prepping the parts that will be installed
Not much progress really since I've mainly been doing what I can to prep my other 86 for sale which the painter tells me will be finished in the next week or so. Primarily, prepping the spare 20v that I have so I can swap it in once it comes back.
Also picked up a couple of these for $20 off ebay, make for great storage options! Even managed to sqeeze the two of them in the back of the golf like they were made ta fit haha.
That's pretty much it for now, will update more in the coming weeks.
Edited by Burcoty
Well done on the file cabinet storage.  I have a bunch of doctors ones that have smaller drawers for my cabinet hardware for work.  So sick.  I got them for free when a colleague ripped out a doctors office.
That 20v looks incredibly sick.  A white block.  The balls on this guy!
That sounds cool, can ya show what they look like? Still trying to think of solutions for smaller odds n ends!
Yeah, it's coming up alright! I actually like the white blocks, they don't stand out as much as ya might think and make it nice and easy to see and trace any leaks/issues!
Edited by Burcoty
Another small update.
Spent the day in the shed, was hoping to acheive more than I did but such is life.
Have done about as much as I can to the prep the 20v. Basically just gotta wait until I get the car back from the painter and transfer everything remaining over.
After I finished playing with that I moved onto this one. Finished painting the rwd water stuff. Came up pretty nice if I do say so myself :p Managed to misplace the connecting pipe tho, don't ask me how, hopefully I don't have to replace it :/
Also started dismantling the front suspension parts, the ball joint were shot and needed replacing and same for the control arm bushes. Thankfully I have new spares of both!
Those damn bushes had cemented themselves in. Had a hell of a time getting the bastards out!
Also found some adjustable rack ends and boots amongst my box of stuff I bought from ajps a few years back, to go on once I've cleaned an prepped the steering rack, which I'm pretty happy about!
That's about it for this week tho, was hoping I'd be close to having the car rolling again today but I'd say I probably have another day's work before reaching that point unfortunately. Still need to swap the column out as well so maybe longer. Hopefully will get some more time to spend on it early next week.
'Till then
Well, for various reasons, I ended up with the day off yesterday and managed to spend most of it in the shed!
So, at 8am in the morning I found myself on then end of a hammer tap tapping ball joints into place, I'm sure my neighbors were delighted lol what I would've done for a press! >_< after a bit of wrangling though I managed to get the bushes and ball joints fitted into the control arms.
Hot tip for anyone thinkin about doing these bushes at home, you can use the bolt, washers and bushes from your sway bar to act as a makeshift press as shown below! Actually worked rather well ^_^
orca-image-1504305254996.jpg_1504305255134.thumb.jpeg.e5b72cda591a5183bd702cf20c52d8a5.jpeg
After that it was just a matter of mounting the T3 knuckles on, I decided not to use the T3 tierods at this stage because 1; they caused issues when I originally took it for a rwc check an 2; I'm not overly happy with the finish of the T3 stuff, it's rough as guts and a bit disappointing that they couldn't take the 60 seconds to run the parts over a linisher before painting them! Not sure if mechanic was just pedantic or what but had the others there so in they went instead.
After that I went on to clean up the power steering, clean and spray the torsion/sway bar mount, install new rack ends, tie rods and boots and reassemble everything all pretty like :p
Once all that was done I could finally remount the whole lot to the car. Unfortunately the torsion bars were wound in super tight and I don't have spanners that big so had to multigrip them *hangs head in shame* Finally got it neutral and bolted up though, along with some skinned knuckles and a little cursing.
Pretty happy I've got to this point, 5 bolts and I can have the struts back in and rolling again shortly after. Hoping to be able to clean them up first but the other car takes precedence once the painter finishes with it.
Next will be to change out the steering column so it all bolts up!
'Till then
