Max666 Posted June 26, 2017 Report Posted June 26, 2017 Hi all does anyone have a step by step, to do a drum to disc conversion on an 82 ke70 please? thanks for any info Quote
ke70dave Posted June 26, 2017 Report Posted June 26, 2017 Pretty much impossible on the standard differential without custom made things. Most people ugprade the differential with something that can take an LSD that also has disc brakes. T18 or ae86 diff is a very popular swap and is well documented. however i don't believe a tail shaft exists that will work with the 4k motor, assuming you still have a 4k motor. 1 Quote
Max666 Posted June 26, 2017 Author Report Posted June 26, 2017 Thankyou Ke70dave in that case, is there a step by step on the ae86 conversion, as this car is a father / son project, and safety is my priority. I'm looking longer term, at an engine swap as the 4K is pretty tired. So the priority is to upgrade the braking for now. Quote
styler Posted June 26, 2017 Report Posted June 26, 2017 Don't worry about the rears, do the fronts first if not done already... and then rears are almost just for drift hydro handbrake antics. Would suggest to convert to ae86 front setup first with brake upgrade for ae86 and then later do t series diff conversion which allows lsd options and drum to disc options... Suspension options also open up with ae86 fronts / t series rear end for more performance... Quote
RainWarriorDregs Posted June 27, 2017 Report Posted June 27, 2017 On 6/26/2017 at 1:37 AM, ke70dave said: T18 or ae86 diff is a very popular swap and is well documented. however i don't believe a tail shaft exists that will work with the 4k motor, assuming you still have a 4k motor. Expand TA22 tailshaft will let you connect a k series box to a T series diff. I have one inbetween a k50 and a RA40 T series diff. Quote
