Hello.
I just noticed today that my KE30 is showing an unusually high speed on the speedo. Infact it's about double of what the GPS on my phone shows. Anyone come across this issue? The reduction for the cable must have skipped a gear, if it's possible at all? It still counts how far the car has driven. Anyone got any ideas? :D
Edited by MrMasternes
Hi Marius,
                 If your speedo "odometer" is still showing the correct number of kilometers the car has travelled, but the speedo itself is showing an increased speed, then the issue is within the speedo itself.  Usually not something you can do to resolve this, although very close inspection of the fine spring & magnet that allow the needle to turn, may disclose/indicate something.  Best see if you can find another speedo.
Cheers Banjo
Edited by Banjo
On 8.6.2017 at 2:48 AM, Banjo said:
Hi Marius,
Cheers Banjo
Thank's for the awnser but the problem magically fixed itself..... The speed was showing the double amount and the odometer was counting km twice as fast, wierd issues....
