CorollaNut68 Posted June 18, 2017 Author Report Posted June 18, 2017 We B Driving! Started first bump...idling about 800. I found the big honking washer that was supposed to go on the cam in the first place. Feels pretty smooth. I had also found a broken spring in the dizzy. Thanks guys. Now I have to replace the leaf springs. If not for the "helper" springs I put on, the leaves would be bowed the opposite way. I found when we replaced a set on a 1962 Falcon that they are the same width and I'm going to just swap a couple of those leaves with a couple of mine. EVen the worn out ones from the 62 will be better than mine right now. I figure if they were designed to hold up a 3/1/2 ton car one or two ought to help keep mine up and maybe not be too stiff. Another experiment in progress... Quote
