Forgot your password?
Or sign in with one of these services
By Radical_Jesus May 26, 2017 in KExx Corolla Discussion
Very Good Point !
Cheers Banjo
21
9
7
3
Jun 1
May 26
6
May 28
4
May 31
Radical_Jesus 21 posts
altezzaclub 9 posts
ke70dave 7 posts
7000rpm 3 posts
Jun 1 2017
May 26 2017
May 28 2017
May 31 2017
May 26, 2017
I personally wouldn't introduced a new igniton system till you have got the original diagnosed. what is the battery voltage, static and cranking? I am thinking the alternator wiring plug may
So, was it running OK when you bought it and before you did the carb conversion?? Started easily and ran smoothly?? Have you changed the ignition system? If it is stock, check that you have
just checking the rotor against the terminal in the dizzy isnt good enough. that for me, has been the difference between the thing starting, or not starting at all. Test for spark, by turnign ign
× Pasted as rich text. Paste as plain text instead
× Your link has been automatically embedded. Display as a link instead
× Your previous content has been restored. Clear editor
× You cannot paste images directly. Upload or insert images from URL.
