tojo2 Posted May 17, 2017 Report Posted May 17, 2017 (edited) jap banjo diffs have a ID code starting with a letter followed by three digits. . Indicates Crown diameter, ratio and lsd or not E7 Corollas came with s,t and u code diffs.+ borg warner for ADM http://www.club-k.co.nz/Forums/viewthread.php?tid=10452 Edited May 17, 2017 by tojo2 add link Quote
briantutu Posted May 18, 2017 Author Report Posted May 18, 2017 Thanks guys for the help, I've been looking around for Borg Warner diff, however they're from cars beside ke70s. Should I stay away from them or will they bolt up as well? Quote
SloRolla Posted May 18, 2017 Report Posted May 18, 2017 Nah, they won't work. Pretty sure only e70s fit 1 Quote
altezzaclub Posted May 18, 2017 Report Posted May 18, 2017 Quote the ke70 has a t50 gearbox, Nope, it shouldn't. The 4K motor fits onto a K40 or K50 box. The A series motors, the 4A-C and 4A-GE fit the T-50, unless someone found a rare K-T bell housing. Check it out and see, the K box has a steel plate at the bottom to access the gears, the T series splits the whole box in half. The K box is slick, light and quick to use, the T box is heavy and solid and clunky. They have different output shafts, so the front of the driveshafts are different. The Borgie and T-series diffs are also different, and a custom driveshaft costs $250-$300. google image the diffs and gearboxes. Quote
Taz_Rx Posted May 18, 2017 Report Posted May 18, 2017 9 hours ago, altezzaclub said: Nope, it shouldn't. The 4K motor fits onto a K40 or K50 box. The A series motors, the 4A-C and 4A-GE fit the T-50, unless someone found a rare K-T bell housing. Check it out and see, the K box has a steel plate at the bottom to access the gears, the T series splits the whole box in half. The K box is slick, light and quick to use, the T box is heavy and solid and clunky. They have different output shafts, so the front of the driveshafts are different. The Borgie and T-series diffs are also different, and a custom driveshaft costs $250-$300. google image the diffs and gearboxes. Is this not the same guy with a 3t in his ksev?.... with the Smokey catch can? And fyi ta22 t50's have the same output shaft size as a k40/50. Quote
briantutu Posted May 19, 2017 Author Report Posted May 19, 2017 10 hours ago, Taz_Rx said: Is this not the same guy with a 3t in his ksev?.... with the Smokey catch can? And fyi ta22 t50's have the same output shaft size as a k40/50. yes thats me :P (catch can isnt smoking anymore!) Quote
